Old 09-22-2007, 01:13 PM
rapscallion rapscallion is offline
Rep: 129 Posts: 412
ultimate 3.5 M tri
I'm ready to build the first 3.5M tri. Could someone send me their ideas in an email so I can actually start building one?
http://janetcg32.blogspot.com
Old 09-22-2007, 04:14 PM
Doug Lord
Google "International 3 meter trimaran" and you'll come up with the class as it is today in the Pacific northwest. I believe the Northwest Multihull Association has free plans from John Marples(ST. Augustine Fl.) But you might have more fun with Chris Ostlind or Kurt Hughes 12 footers. 3 meters is just too small, in my humble opinon. The cost difference will not be too significant but the performance difference surely will.I think building a class with 12 footers may
be easier than with the 3 meters.
I might even be interested in doing a 12 footer if the rules can be agreed upon stipulating a MINIMUM crew weight of 220 pounds(for racing only).....
NWMA - 3 Meter
Address:http://nwmultihull.org/3meter/3mtr.htm Changed:9:35 PM on Wednesday, January 10, 2007
12' trimaran
Address:http://www.multihulldesigns.com/stock/12tri.html Changed:4:49 PM on Sunday, November 26, 2006
Old 09-22-2007, 10:58 PM
Rep: 129 Posts: 412
220 lbs? I don't have a problem with that.... but what do us skinny guys do... Add weight to the boat?
Old 09-22-2007, 11:06 PM
Rep: 129 Posts: 412
stressed ply would probably be the lightest way to go, but I'm thinking of using PI foam (cheap) with cheap stringers... and set up the mast without spreaders.
I have a Kurt hughes design book. I'll do the best I can from that I guess.
If it doesn't fall apart right away maybe I'll slap some foils on it.
Old 09-23-2007, 07:24 AM
Doug Lord
Lightweights
Since small unballasted performance boats are so sensitive to weight it makes sense to me to have a weight equalization plan that ensures everyone is on the same level. And since you would sit in the middle like a 2.4meter(or Kurt Hughes 12 and Chris Ostlinds 12) the equalization weight could easily be added in one place since it doesn't have to be movable.
So designs for this "class" would require that the crew sat in one place and that the minimum "crew" weight was 220. A minimum all up boat weight might be required to prevent a carbon war.
Maximum SA?(suggestion: 100 +120 spin?)
OR:
Let the heavyweights carry more SA upwind and down so that the lb.of sailing(boat + crew) weight per sq.ft. of SA is the same .
Example:
Lightweight- 160lb. boat +160lb crew=320lb.. SA= 100 sq.ft. or 3.2 lb/sq.ft. SA
Heavyweight- 160lb. boat weight + 220lb.=380lb.
SA at 3.2 lb. per sq.ft.= 118.75 An additional "weight factor" might be required that would increase the "heavyweight" SA a bit to account for having a heavier boat on the same waterline length.
Just a few ideas-the concept of a small, fast tri with a wide crew weight range interests me. A boat like this could easily become a lightweights only class unless the founders of the "class" plan for a wide range of crew weights.
Old 09-23-2007, 09:24 AM
Rep: 129 Posts: 412
good thoughts Doug...
I like the idea of adding ballast to make up for crew weight the most, simply because it seems to be the easiest way to manage the differences at a regatta.
I also like a minimum weight to prevent a carbon war. My thoughts on such a class would be a VERY high performance development class that was dirt cheap to participate in and could easially accomidate disabled sailors...
we could do a 3.5M box rule with a minimum weight and maximum SA (still not sure what that would be)
But the one thing I wanted to throw in the ring is that the boat CAN'T turn turtle. I was going to form a foam/epoxy wing to go on the top of the mast that would act as an endplate for the foil and provide enough ballast to prevent the boat from turning turtle.
It should actually make the sail more efficient and add safety for those sailors who would have a hard time getting out of the boat if she went over.
Anyone know where I can find info on calculating scantling numbers for multihulls?
Old 09-24-2007, 07:26 PM
jamez jamez is offline
Rep: 184 Posts: 272
What about....
http://www.teamscarab.com.au/Scarab350.html
Ultimate 18' Tri ? Doug Lord Multihulls 28 02-04-2008 06:52 PM
The Ultimate Coastal Cruiser... Sean Herron Boat Design 6 09-25-2005 10:18 AM
The Ultimate Sailboat Brasstom Boat Design 17 08-07-2005 07:50 AM
The Ultimate Sailing-Cruiser? Brasstom Sailboats 21 08-03-2005 12:31 AM
Ultimate rudder design SamK Sailboats 1 03-19-2004 12:01 AM
