Old 09-01-2011, 05:55 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,601
Trimarans: Angle of Heel at Main Hull Takeoff
I'd appreciate all the help I can get from designers and sailors with getting information on the main hull take off angle of heel of as many trimarans as possible.
This is with the main hull "just kissing" (say 1mm above the water) .
I've run into wide variations and I'm interested in getting lots more info for which I will be very grateful.
Some that I know or have found:
1) RC model-slightly oversquare moderate main hull rocker: 13 degrees, (accurate)
2) My new design-wide main hull, little rocker: 10 degrees, (tentative)
3) USA-17: 13 degrees, (accurate from Oracle)
4) many other tris are much higher-one I measured here was 26 degrees!
Again, your help would be most appreciated!
--At this point I don't necessarily need analysis of why the angle is as it is(beam, weight SA, dihedral etc) just the angle will be ok. But analysis is ok-even great- just not absolutely required right now. Thanks.
-- Estimates are ok-just mention that's what it is.....
yes, it is a revolution
Old 09-05-2011, 01:44 PM
Doug Lord's Avatar
Flight Ready
Multi 23 measured off the video= 18 degrees with main hull partially flying. Deeper than "just kissing"- middle of main hull still underwater. Probably 20+ degrees with main hull clear.
http://www.youtube.com/watch?v=x--tq...layer_embedded
USA-17 Measured off video to cl of boat, not mast= 13-15 degrees: http://www.youtube.com/watch?v=10XH3Fehn40&NR=1
Old 09-07-2011, 03:51 PM
bruceb bruceb is offline
Rep: 153 Posts: 565
lift off
Doug, I don't quite understand comparing such different designs, but lightly loaded (just me and some sails), my buc 24, with a lot of rocker, has all but the bottom few inches out at around 26-28 degrees. That really feels like a lot, almost mono type heel, but the Buc isn't really designed to lift the main hull. The floats are about the same displacement as the design load, so with normal loading, the float buries before the main hull ever lifts and the boat rounds up, so I have read- I haven't pushed it that far- yet I suspect many of the tris with smaller floats do the same. B
Old 09-07-2011, 04:11 PM
Doug Lord's Avatar
Flight Ready
Thanks, Bruce-that's just the kind of info I was looking for. I'm just taking the info at face value -not necessarily analyzing what it means right now.
I think there will be big differences between tri's designed to fly and those that aren't but there is a lot more to consider when attempting to determine which is better or worse and what it might be better or worse for.
Again, appreciate it!
Old 09-11-2011, 11:29 AM
Doug Lord's Avatar
Flight Ready
I'll tri to find a picture from a point with the main hull 1" off the water for the Sea Cart 26 but take a look at these pictures and compare to the ama submergence of the M23-and its not quite flying the main hull.
These shots illustrate perfectly a curved lifting foil doing exactly what it is supposed to do-the ama bow is clear with the main hull way up-that is good design!
http://seacart26.com/
Can't find a suitable picture to measure takeoff angle but it looks like it would be fairly high....
UPDATE-9/15/11: According to a Sea Cart company employee the estimated takeoff angle when using the curved foil is 13-16 degrees.
click on image:
Trimarans: Angle of Heel at Main Hull Takeoff-sea-cart-26-2-their-site.jpg  Trimarans: Angle of Heel at Main Hull Takeoff-sea-cart-26-their-site.jpg
Old 09-11-2011, 02:24 PM
Hussong Hussong is offline
Previous Member
Rep: 30 Posts: 63
Isn't this fundamentally misleading?
Price for M23 ready to sail: $38K
Price for Seacart 26 ready to sail: $130K
Old 09-11-2011, 05:06 PM
Doug Lord's Avatar
Flight Ready
Hussong, this thread is about: "Trimarans: Angle of Heel at Main Hull Takeoff" and I would very much appreciate it if we could try hard to keep it on the original topic.
Your question is interesting and you might want to go ahead and start a thread on pricing and the ramifications of certain pricing schemes-in fact I think it is a good idea!
Old 09-11-2011, 11:13 PM
Previous Member
Rep: 30 Posts: 63
The point is this: If you are going to say that, with reference to the Seacart 26, "...These shots illustrate perfectly a curved lifting foil doing exactly what it is supposed to do-the ama bow is clear with the main hull way up-that is good design!" By inference, you are also suggesting that the M23, which has no lifting foils, is a less than good design. The M23 is designed by VPLP out of France, They are responsible for many of the state of the art trimaran designs today. I hardly think that they are without the understanding to produce a "good design".
I think that they are two totally different boats with entirely different slices of the market. One is $38K and the boat that you say is good design, is significantly more at $130K. It seems to me that if a manufacturer wishes to keep costs under control and produce a truly fabulous trimaran in the under $40K region, that lifting foils become a unique and very pricey add-on that will certainly take the boat into the $50K region and well out of the targeted market segment.
Comparing the less expensive boat to the radically more expensive boat and then further coupling the expensive product with a good design claim is inappropriate in my estimation.
Perhaps if you compared boats with equal costs and features, your comparison would be more valuable. As it is, this is not a direct comparison and has little value.
Old 09-12-2011, 08:12 AM
Doug Lord's Avatar
Flight Ready
This thread has nothing to do with "slices of the market"- only the technical differences related to the main hull takeoff angle of heel. Please start your own thread about "slices of the market", pricing as they may relate to a boat's technology etc.
My remarks were not intended as inferring anything about the M23. My comment about "good design" was related to the functioning of the curved lifting boards on the Sea Cart 26. Both boats appear to be good trimaran designs. Because of the differences in design the comparison of the M23 ama submergence and Sea Cart ama submergence(or lack thereof) at or near hull flying angle is within the topic of this thread.
Old 09-12-2011, 10:02 AM
Rep: 153 Posts: 565
lift off
Doug, thanks for posting the Sea cart pics- I am interested, even if my budget is somewhat less. The under-body views tell a lot. I did notice quite a lot of rudder angle in both pics- I wonder if they were trying for "air". In the budget department, I have one of my foils finished and working- at last. I built the trunks before the foils and didn't get the fit quite right, but with enough sanding in the trunk, all is well. I will get some pics up soon, but with my first test sail, the a-board feels great. It definitely is lifting the float both up and to weather- of course, I don't know yet how much drag has increased. I do know that my budget for both trunks and boards is about $500 US, so lifting a-boards are not just for the wealthy B
Old 09-12-2011, 10:09 AM
Doug Lord's Avatar
Flight Ready
Looking forward to seeing them, Bruce! Are they curved or straight angled boards? Check out the video here of the Catri 23-straight angled boards plus a couple of small anhedral foils off the transom:
http://www.youtube.com/watch?v=20tULUapaMM&NR=1 Didn't get a good measurement but I'd guess just about 13 degrees with the main hull just kissing. Fairly small amas and the foils are doing their job.....
Old 09-12-2011, 01:47 PM
Rep: 153 Posts: 565
more lift
my boards are also straight, little smaller and are right behind the crossbeam, and mine are probably 5 degrees more vertical so I won't get as much lift as the Catri. I have bigger floats and the Buc isn't as fast, so I was looking for more lift to weather. A friend has a Nacra 20, and from watching his boat, curved foils do require some adjustment for conditions, where the straight boards are somewhat less effective but also more forgiving. Also, I have enough trouble making a straight board, and a pair of curved ones would probably take me all winter I like to experiment, but I also like to sail, not sand. B
Old 09-12-2011, 02:32 PM
Previous Member
Rep: 30 Posts: 63
Spot on, bruceb. You've touched on the very reason why the M23 is not equipped with curved foils as suggested by others here. Cost/Time effectiveness in the build, which is the same as the manufacturer saying they are too expensive and not needed for what is already a great design.
Ama foils play an insignificant part in the angle of heel when the main hull leaves the water.
Old 09-12-2011, 02:54 PM
Doug Lord's Avatar
Flight Ready
Bruce, is your boat a Buccaneer 24?(update-just read your earlier post about your Buc 24!--I guess it helps to read those earlier posts!) What's the scuttlebutt about foils on those boats-any info?
Old 09-12-2011, 04:30 PM
Previous Member
Rep: 30 Posts: 63
It is true and if you actually work out the physics accurately, you will see it to be so.
Simply put; what forces cause the main hull to rise and what forces prevent it from doing so? Where does the center of gravity location benefit the lifting of the hull and under what conditions does the COG have a more difficult time of lifting the main hull?
Lift from foils is not generated immediately, where heeling moments happen long before the foil is accelerated and capable of generating lift. The function of main hull lift has everything to do with the design of the base structure of the boat and the designed flotation of the ama relative to the heeling moment potential of the rig.
Best method to takeoff model half hull? bntii Boatbuilding 5 05-05-2011 11:48 AM
Veal Heel for Small Trimarans Doug Lord Multihulls 6 03-31-2011 05:48 PM
Relationship between angle of attack of keel and heel angle stelios Sailboats 9 05-29-2006 02:14 PM
Static heel Angle Aproximations budner1 Boat Design 2 05-15-2005 11:09 AM
Optimum heel angle Blether Sailboats 9 06-09-2004 06:46 AM
