  #31
Old 08-28-2011, 05:20 PM
kiwi_bob kiwi_bob is offline
Rep: 10 Posts: 12
Building a retractable DSS system is adding the complexity, weight and effort I was hoping to avoid... but yes it would be a good soln but not for me.
I may revisit this once I have my tri complete and if I find my smaller volume floats an issue - in the meantime my plan for the very heavy conditions will involve reefing :-(. Thanks guys esp Doug for your input (Doug, do you ever sleep??)
Cheers
Dean
  #32
Old 08-28-2011, 06:23 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,601
Bob-Dean, what boat are you building? Is it designed to fly the main hull?Hope it goes well!
yes, it is a revolution
  #33
Old 08-28-2011, 07:45 PM
Rep: 10 Posts: 12
I'm building a trimaran for the Kiwi 8.5m box rule. Yes the plan is to get the main hull flying - float rudders etc. The floats are I believe adequate volume for that purpose but time will tell. I'd like to get the basic boat going first and then look to apply some appropriate foil technology down the track...
  #34
Old 08-28-2011, 09:00 PM
Doug Lord's Avatar
Flight Ready
Two last questions: 1) what is the Length divided by Beam ratio of the ama
2) what is the total immersed displacement of the ama compared to total boat weight incl crew? (80%, 100% ??)
Thanks for the info and good luck!
  #35
Old 08-28-2011, 10:01 PM
Rep: 10 Posts: 12
Hi Doug
Length divided by beam is 8.5/.07 = 12.14%
and total displacement of ama is approx 1800kg - weight with crew (with luck) should be approx 1200kg (I hope, possibly less) - should give a value of approx 150% (which as I understand it is the minimum for hull flying - hence why I'm interested in foils - each ama weighs approx 80Kg. I hope to be sailing this southern summer.
Cheers
Dean
  #36
Old 08-29-2011, 09:27 PM
Doug Lord's Avatar
Flight Ready
Dean, here's Farrier's F-85SR design to the NZ 8.5 rule:
Basic dimensions are
L.O.A. - 8.5m (27' 10")
B.O.A. - 6m (19' 8")
Mast Height - 11.3m (37')
Sail Area (main and jib) - 42sq.m (455sq.ft)
(uses F-32 curved foils cut down)
click on image:
Trimaran lifting foil alternative-farrier-f-85srprofile-nz-8.5m-rule.jpg  Trimaran lifting foil alternative-farrier-f-85srbodyview-nz-8.5-rule.jpg
gelcoat alternative dinoa Fiberglass and Composite Boat Building 1 01-23-2010 01:10 PM
Alternator alternative?? steveroo OnBoard Electronics & Controls 13 01-01-2010 11:59 AM
Alternative propulsion Wemdoug Propulsion 2 01-01-2010 06:01 AM
Lifting Hydrofoils(foil assist) in the Americas Cup!!!(?) Doug Lord Multihulls 17 09-22-2008 03:54 PM
R/C trimaran hull shape and foil suggestions Mitch M Multihulls 10 02-08-2008 08:30 PM
