Old 07-18-2008, 07:19 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Trampoline Material
Hi Everyone,
The trampolines you get on the multihulls (where the girls tan on ) -
What material is it made of, and how thick is it ?
Regards
Fanie
Water ! Just gimme water !
Old 07-18-2008, 07:24 AM
northerncat northerncat is offline
Rep: 9 Posts: 170
go and buy some trawler net with small holes from a trawler supply co, cheap comfy and very very durable
sean
Old 07-18-2008, 07:31 AM
Fanie's Avatar
Fanie
Hi Sean,
Thanks, good idea. What is a trawler supply co ? Guys sels fishing nets ?
I still need to know what it is made from.
Regards
Fanie
Old 07-18-2008, 11:17 AM
tspeer tspeer is offline
Rep: 1329 Posts: 1,523
Trampolines are made out of a number of different materials. One issue is how porous you want the tramp to be. Porous fabrics are comfortable, but shed water slower and can produce more windage when the yacht is heeled at large angles. Netting doesn't have these problems, but isn't as comfy on bare skin.
I used netting from Net Systems when I made the tramps for my cruising trimaran. I went with Dyneema netting with a cell size of 1" squares. Nylon netting with 2" squares is also used on cruising boats.
Sunrise Yacht Products is one of the largest manufacturers of trampolines for multihulls. They have a wide variety of materials and colors.
Tom Speer
Old 07-18-2008, 01:31 PM
Fanie's Avatar
Fanie
He he... I like your thinking, Tom
The netting sounds better and better. You don't want them to just lie (lay) there all the time. Who'll make the food ?
Does any of the SA guys know of a trawler net supplier ? I'll google and see what comes up. Thanks for the responses.
Tom, bothers me a bit the yacht heeled at large angles Mono's use netting as well now
Regards
Fanie
Old 07-18-2008, 01:46 PM
Fanie's Avatar
Fanie
The 25mm and 50mm large holes are quite large. I've seen some video's where the trampoline looks almost like shade netting, and you can see the sparay goes through it.
The trampoline on my friend's small trimaran is fine and smoother than shade netting, leaves no pattern as Tom said 'on the bare skin'. Can't say that it is thinner than shade netting, but it looks more like a nylon and it is finer woven.
Regards
Fanie
Old 07-18-2008, 07:43 PM
Rep: 9 Posts: 170
mine has about an inch hole and is very very confortable
sean
Old 07-18-2008, 08:02 PM
deepsix deepsix is offline
Rep: 94 Posts: 124
I really like the bainbridge heavy duty mesh, it is a woven polyester mesh with a vinyl coating. The tramps are made by welding the material, not sewing where the stitching eventually fails due to UV. This is very expensive though.
http://www.sail-making.com/dbimgs/Mesh%20UK.pdf - last page.
The mesh that you saw on the windrider is probably the standard hobie tramp material, but it is probably not strong enough for bigger boats.
Old 07-19-2008, 04:29 AM
Fanie's Avatar
Fanie
Thanks... yes the ultrasonic welding makes sense, it would be stronger than sewing.
Only one person can go on the windrider's tramp... it won't be strong enough for much more.
I'll find out about the netting. If it's strong, durable, cheap and can leave some interesting imprint on bare skin then it may be what to get. Maybe even catch something if you burrough into a wave
Regards
Fanie
Old 07-22-2008, 07:59 AM
Splash Gordon Splash Gordon is offline
Rep: 26 Posts: 13
Howzit Fanie!
Get hold of Alnet or better still get hold of I&J Trawling here in CT and see what they can do for you, otherwise try Johann at Ropeworld- he'll make you custom nets out of whatever you want, any size you like.
FWIW, I know the hardcore and wannabe-hardcore cats use Vectran netting ($$$$!!!) which they roll up at the edges, then they lash the bundle to the boat. I think it looks kak, but then I'm not hardcore- cruising-cats aren't meant to be either!
Old 07-22-2008, 03:58 PM
Fanie's Avatar
Fanie
SPLASH Gordon eh
I phoned Alnet, they are around the corner here in jhb from me. I think they forgot to phone back. Will remind them to phone back
It will help if one knows someone at I&J...
Could try ropeworld also... thanks.
Check out the rigging on the pics
Regards
Fanie
Old 07-22-2008, 04:28 PM
Trevlyns Trevlyns is offline
Senior Citizen/Member
Rep: 461 Posts: 689
... Trampoline material? Flash Gordon? How DO these threads get so out of hand
Trev F – Amateur designer and part-time layabout.
Old 07-22-2008, 04:50 PM
Fanie's Avatar
Fanie
Hi Trev... aaaww you know how it is... takes all sorts Found them on the net Good example of too much trampoline. As Splash said you have to be hardcore to like it
Trampoline Material-painted1.jpg  Trampoline Material-painted2.jpg  Trampoline Material-painted.jpg
Regards
Fanie
Old 07-22-2008, 05:04 PM
Rep: 461 Posts: 689
Bluebottle (from the Goon Show - circa 1952) had the perfect reply...
... You Silly Twisted Boy, You
Old 07-22-2008, 05:06 PM
Fanie's Avatar
Fanie
Sorry Oom Trev, sal nie weer nie
Regards
Fanie
Catamaran trampoline jimmi Multihulls 49 12-22-2010 10:50 PM
Trimaran: netting/trampoline attachments dannyb Boat Design 6 11-18-2005 07:53 AM
boat material / furniture material bogeyinthekeys Materials 7 09-10-2005 09:29 AM
I removed the wooden plateau and replaced it with a fabric trampoline - stability?? Gregor_L Sailboats 2 04-10-2005 09:28 PM
Best Material Aquaholic Boatbuilding 1 09-25-2004 06:27 PM
