#31
| why build a male mould? |
#32
| a good idea, but that layup? |
#33
| What is wrong with the layup given to you on Multihull forums by Steve Turner? Sounds on the money to me. If not consult the designer or get a layup from your materials supplier. At some point you are going to have to make a decision and start building. My only advice at this point would be use a top quality gelcoat and use a vinyl ester tie coat behind or all ve layup. Cheers, Reuben |
#34
#35
| http://www.multihullforum.com/ The best forum off multihull!!!!!!!!!!!!!! |
#36
| Thanks! But what I meant was a link to the mentioned post with the layup given to you by Steve Turner. Regards, Angel |
#37
| You will need to log in/register to read it. \The thread is http://www.multihullforum.com/forum/...?TOPIC_ID=3988 |
#38
| in full Steve Turner said, "Hulls: Gelcoat, 200 gram powder bound CSM skin(tie coat),300/150 gram biaxial combination mat,Lantor Coremat XM 4mm, 300/150 gram biaxial combination mat. Extra layers along keel, stem, stern etc. Decks: Same layup but substitute 10mm PVC foam for coremat eg Airex C70. Beams: Make standard wooden beams, or use aluminum alloy tubes, 4" (100mm) OD x 10 gauge wall (3.3mm) Are you planning to build a female mould, or make flat panels? If flat panels, you will need to join them before laminating the inner skin. Are you an experienced laminator? If not, hire one and labour for them! Steve" |
#39
| Here’s a reply from Richard Woods on the method I received via email, Quote:
__________________ "Never to land on an island from a boat of one's own building, is to miss one of life's great moments." -- Arch Davis |
| Wharram Tiki wrecked in Thailand | sloopjb | Multihulls | 194 | 04-20-2010 03:20 PM |
| Looking for Unused Wharram Tiki 30 Plans | tatoski | Marketplace | 1 | 11-23-2009 08:33 AM |
| Tiki 21 plans wanted | gpb | Multihulls | 0 | 09-04-2009 09:17 AM |
| Wharram Tiki 26 vs Woods Strider Club | resynth | Multihulls | 8 | 05-03-2009 11:22 AM |
| Looking for Tiki 30 plans. Can change for Coral Sea 35 plans | filiperosa | Marketplace | 2 | 12-29-2006 08:26 PM |
