Old 02-14-2010, 06:43 AM
fabrice fabrice is offline
Rep: 10 Posts: 53
yes you're definitely right.
the beauty of the kayak stabilizers (gull wing style) is in the preservation of the leaning ability, essential in kayak.
A reason why outrigger canoe are a pain in the ass to turn.
Hum, I've got an aching shoulder resisting treatements, I must confess your pedal drives are becoming sexier every time I look at them !
Do you think possible designing such a boat for sea trips ?
Maybe you already did ?
Old 02-14-2010, 02:48 PM
Rep: 10 Posts: 53
Originally Posted by Rick Willoughby View Post
A good sailing tri would have vastly different outriggers.
I clearly understand that, now.
So my canoe could be good at paddling, or at sailing with the accurate set of amas lashed on it, but not in the same trip !
It's difficult, maybe impossible, to design a boat doing well in every kind of propulsion.
Or maybe a rowing and sailing boat do this, like a withehall.
Far away from the initial subject, indeed.
Old 02-14-2010, 03:33 PM
Previous Member
Rep: 0 Posts: 0
Fabrice
I have done one design that has been built for an ocean crossing with safety and long range being the priorities. It is much faster than rowing boats for the same purpose but not really suitable for brief periods in the open sea.
There is a range of possibilities depending on the level of weather protection ranging from completely enclosed to completely open. The attached shows some possibilities.
Rick W
thoughts on ama drag : outrigger design-picture-2.png  thoughts on ama drag : outrigger design-picture-3.png  thoughts on ama drag : outrigger design-within.png
Old 02-14-2010, 04:11 PM
Previous Member
Rep: 0 Posts: 0
Favrice,
Here's my suggestion as a designer of multihulls...
Weigh your potential use needs and give them a value as a percent figure. Design a main, canoe hull, that addresses the needs weighting, while offering the kind of capacity and use you intend. Create a design solution for a single set of amas that live decently in each camp and then enjoy the daylights out of the boat. Use it for several seasons on the water in all the ways you intend and then re-assess the design.
Pushing the boat in one direction to excess will make it a dog for anything else. There's always going to be some optimal type for any particular application, but it will not make for an adaptable craft for your recreational family needs.
It is possible to bridge the chasm between the two disciplines and still get a nice, all-around boat. I've done several designs to a similar formula and they are quite successful as adaptable, modular systems that can be comfortably paddled, motored or sailed.
Most of all, create a boat that is so much fun that you want to use it all the time.
Old 02-16-2010, 05:33 AM
Rep: 10 Posts: 53
Well thank you so much all of you for the very good explainations and suggestions.
I'm going back to the drawing board, and scratch my head to really frame the intended use, with fun in mind !
Thanks again for your time.
Delftship Design Question on Design Drag vs Hull Ratio Fanie Boat Design 10 06-08-2009 06:43 AM
Length of ama on outrigger canoe? dogfuel Boat Design 10 04-17-2009 03:18 PM
ama design for 60' alum circumnav tri guppy Multihulls 1 05-09-2007 01:10 PM
Design thoughts on a 9" wooden Sailboat JohnBloch Sailboats 0 06-12-2006 05:59 PM
hawaiin outrigger hull design Guest Boat Design 2 03-25-2004 08:15 AM
