Old 02-09-2012, 03:41 AM
Franzi.v.B.'s Avatar
Franzi.v.B. Franzi.v.B. is offline
Rep: 10 Posts: 22
Hi Hielan,
yes, that would be cool.
Thanks,
Franzi
Old 02-11-2012, 04:39 AM
pogo's Avatar
pogo pogo is offline
Rep: 17 Posts: 57
One of the dutch Kraken is the "Hokus Pokus", a fast boat pointing very high.
The other one is "Het Verstand van Pooh", her mast is shorter for less hobbyhorsing--Krakens are known for this.
"Het Verstand van Pooh " is since building in the hands of one family and still wins races.
In the Netherland also exists at least one Buccaner 33, Kraken`s cruising sister with much more interior volume.
Adresses of the current owners are available via CTC.
pogo
Immer handflach Wasser unter`m Schwertschlitz !
Old 02-11-2012, 01:14 PM
Corley Corley is offline
epoxy coated
Rep: 524 Posts: 630
I've thought in the past that a carbon mast would be of huge benefit to Krakens and Twiggys. Ian Johnston cut a small amount off the top of his Twiggys mast and it improved the boats manners enourmously. I've had a carbon wing mast drawn for my Kraken 25 will be interesting to see how it goes.
Old 02-21-2012, 01:55 PM
Rep: 10 Posts: 22
@Corley
Interesting. Who drew your Carbon mast? How much was the person asking for it? Any other comments?
Thanks,
Franziska
Old 02-21-2012, 04:16 PM
epoxy coated
Rep: 524 Posts: 630
My mast section was drawn for me by Chris Tucker at Chris Tucker Marine Design. http://www.ctmd.com.au
He offered two configurations a)design of bare section or b) full design of mast, spreaders and mast base. I opted to just have the bare section designed his design fee was very reasonable. He will probably need some info on your boat such as a sailplan and possibly some info on displacement, righting moment etc.
His website looks to be mostly about commercial boats but he is a keen sailor and races off the beach mosquito catamarans.
Chris gives you some weblinks to look at for DIY'ing your mast and the design is certainly within the scope of an amateur builders skills to construct. I'm going to build mine simply because I've not built a mast before and am interested in the method.
Old 02-22-2012, 03:37 AM
redreuben redreuben is offline
redreuben
Rep: 164 Posts: 352
Some good info here from Applied Engineering Services in NZ
http://www.aes.net.nz/comment19.html
Lock Crowther 1962 Kraken 25 trimaran build and rebuild log Corley Multihulls 46 05-22-2012 06:54 PM
Lock Crowther Kraken 25 Trimaran. oldsailor7 Multihulls 89 12-13-2011 02:47 AM
Kraken 25 trimaran rebuild and question re: boarding step for off the beach tri Corley Multihulls 11 07-19-2010 08:14 PM
Information needed on Kraken 25 or other Kraken LucD Multihulls 32 04-22-2010 07:42 PM
Kraken 33 Niels Boat Design 3 03-15-2004 02:05 AM
