Old 09-24-2013, 04:16 AM
Corley's Avatar
Corley Corley is offline
epoxy coated
Rep: 826 Posts: 3,457
Team Macif to join the Ultime trimaran club
Team Macif have added their support to the Ultime class with VPLP scoring a design request for an oceanic racing trimaran of around 100' to be skippered by Francois Gabart. An extensive and ambitious program of solo events ultimately working up to a solo round the world attempt.
http://www.macifcourseaularge.com/ac...-macif-en-2015
and an article on the dailysail:
http://www.thedailysail.com/offshore...rancois-gabart
I thought it would be interesting to do a comparison with the current holder of the record Francis Joyon and IDEC II and challenger Thomas Coville's Sodebo
My observation from the provisional specs is that VPLP are pushing the beam out relative to the Iren's designed Sodebo and IDEC it's still not extreme but will provide more righting moment. This boat will have a 20m (65') beam approximately vs about 16.5m (54') on Sodebo and IDEC.
Macif
A trimaran of about 100 feet long in the final category, intended for offshore navigation alone.
Length: 30 m
Width: 20 m
Mast height: approx. 35 m
Surface of sails to the close: 600 m²
Downwind sail surface: 700 m²
Sodebo
Mise à l'eau : juin 2007
Port d'attache : La Trinité sur Mer
Architectes : Nigel Irens / Benoît Cabaret
Calcul de la structure : John Levell
Dessins des appendices : Martin Fischer
Etudes hydrodynamiques : Yann Roux
Constructeurs : Boat Speed (Australie)
Poids en charge : 12 tonnes
Mât : basculant 35m
Surface grand-voile : 237m²
Surface solent : 158m²
Longueur : 31 mètres(102 pieds)
Largeur : 16,55 mètres (55 pieds)
Toutes les voiles sont en Cuben Fiber ou en D4
IDEC II
Longueur hors tout : 29.70 m
Longueur flotteurs : 24.5 m
Largeur : 16.5 m
Poids : 11 t
Surface de voilure au près : 350 m²
Surface de voilure au portant : 520 m²
Hauteur de mât : 32 m
Chantier : Marsaudon Composites Lorient
Mât et bôme : Lorima
Appendices : Gepeto
Calculs : Hervé Devaux
Voiles : Incidence Brest
and for comparison Groupama3's specs, this is the Jules Verne trim so the mast fitted for the Route du Rhum was shorter (anyone know how long the "short" mast is ?). The sail area and mast height were reduced for the Route du Rhum when Franck Cammas solo raced the boat to victory.
◾Build date: 2006
◾Architects: VPLP
◾Type: Trimaran
◾Shipyard: Multiplast
◾Length : 31.50 metres (103.3 ft)
◾Width : 22.50 metres (73.8 ft)
◾Displacement : 18 tons
◾Mast height: 41 metres (135 ft)
◾Sails : 557 sqm / 828 sqm
◾Crew: 10
and the solo specs with shorter mast and renamed BPVII
Architectes : Cabinet VPLP
Nom officiel : Maxi Trimaran Solo Banque Populaire VII
Numéro de voile : 19
Longueur : 31,50 m
Largeur : 22,50
Déplacement : 18 000 kg
Tirant d’eau : 5,70 m
Hauteur du mât : 33,50m
Structure : carbone-Nomex
Voilure au près : 411 m2
Voilure au portant : 678 m2
Toute première mise à l’eau : juin 2006
Multihull Yacht Club of Victoria
https://www.facebook.com/MultihullYachtClubOfVictoria
blog/projects http://trimaranproject.blogspot.com.au/
Old 11-28-2014, 04:59 AM
Corley's Avatar
epoxy coated
A video showing construction progress at CDK technologies on the new Macif Ultime trimaran to be skippered by Francois Gabart.
http://youtu.be/kAWwoBPDc1o
Old 02-13-2017, 11:31 AM
Doug Lord's Avatar
Flight Ready
Rep: 1362 Posts: 13,605
Macif
Article: http://iq.intel.com/smart-sailing-fr...ting-tech-lab/
yes, it is a Revolution
WOLF-daughter of fire arrow
Fire Arrow Foil System-small and large trimarans!
Old 02-13-2017, 05:30 PM
RHP's Avatar
RHP RHP is offline
Rep: 1183 Posts: 774
Wow! Far out construction and far out operation! Top 1% only thank goodness.
Old 03-15-2017, 10:17 AM
Doug Lord's Avatar
Flight Ready
Macif Test Boat
Striking new 24' foiler from Macif/Francis Gabart :
This boat is being used as an experimental test boat close to scale of the full size Macif to test foils and foil combinations. In the picture below you can see two different ama foils both of which work like uptip foils with intrinsic altitude control. Both amas have rudder T foils.
http://www.macifcourseaularge.com/ac...la-performance
https://www.facebook.com/hashtag/m24...82012811878630
NOTE: One of the French guys on facebook claims that the daggerboard has a "horizontal plane, trim everything". Just spectacular if true!UPDATE-no evidence found for this claim anywhere so far.
Sodebo team buy Geronimo maxi trimaran Corley Multihulls 7 06-29-2015
04:50 PM
Team Lalou's new Multi 50 trimaran Corley Multihulls 61 09-10-2013
11:03 PM
Traspac Race Record Team Tritium/Lending Club Corley Multihulls 15 07-28-2013
06:21 PM
Team Australia (KAS) and Team Vodafone to do battle to decide who is fastest Corley Multihulls 13 10-11-2012
10:52 PM
If you cant beat 'em, join them rwatson Boat Design 7 08-16-2008
08:08 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
