Old 07-06-2012, 04:45 PM
smallyachtsailr smallyachtsailr is offline
Rep: 10 Posts: 17
Tacking a trimaran vs tacking a proa
Hi all. I'm here to pick your brains. I have a small (tiny!) trimaran and am happy with it--it tacks easily and responds to the rudder well. I have no experience with proas. I'm working on a larger and faster lightweight trimaran (14' or so) design for car-topping. I often sail in narrow and sometime crowded waters, so I need a quick-tacking and maneuverable boat.
I'm considering a lot of different possible designs, although I'm focusing on another multihull. I've sailed hobies and was very underwhelmed by their tacking abilities. So catamarans are out. That leaves a trimaran, or a proa. To my mind, if I leave one ama off the trimaran and make it a proa I save a lot of weight and mass and beam--which means potentially a faster boat, and less to load on top of my car. But then as a proa, the one ama rarely leaves the water. A shunting proa simply doesn't look like a good idea in a narrow river or crowded anchorage (or am I wrong?). I have no experience and no idea how maneuverable a proa is in narrow waters. For example, I often have to tack between bridge abutments in a narrow river, against a tidal current. My small tri handles this easily, tacking only inches away from the concrete abutments.
Here's the question:
****All else being as equal as you can get it, which is more maneuverable, especially tacking, a trimaran, or a (tacking type) proa?****
Another way of phrasing it: Is the second ama worth it?
Old 07-06-2012, 04:52 PM
Doug Lord's Avatar
Flight Ready
Rep: 1102 Posts: 7,591
I have no experience with proas either but Rob Denney is a member here and could enlighten you about proas and shunting etc.
Was the small trimaran you were considering going to be designed to fly the main hull?
yes, it is a Revolution
Old 07-06-2012, 05:04 PM
Rep: 10 Posts: 17
Thanks for the quick response Doug.
No, not a flying main hull. I'm also intrigued by the foil trimarans (Hydroptere!!!) but I have no experience with designing them--are the foils made of glass or steel? I'm going for an easy to sail lightweight tri (or proa?) that is faster than most boats its size, and also maneuverable. I've been designing solidly down the trimaran path, but have always wondered about proas and whether I could simply chop off one ama and some length off the crossbeams. Its tempting, but I'm afraid I'll lose too much responsiveness to the rudder. I've seen a couple proas in the area but haven't had the opportunity to try one.
Old 07-06-2012, 06:28 PM
Doug Lord's Avatar
Flight Ready
You should,without a doubt, sail one before you try to design one and that goes for the tri as well. Since you're not flying the main hull it seems like you wouldn't lose a whole lot(if any) performance to the proa configuration. Good Luck!
PS-Foils these days are made of carbon fiber/epoxy.
Old 07-06-2012, 06:39 PM
Rep: 1743 Posts: 8,439
Proas traditionally shunt not tack. The bow becomes the stern and viceversa.
Old 07-06-2012, 06:43 PM
Rep: 148 Posts: 1,325
I always doodle them so they shunt like a proa and tack like an outrigger for narrow channels or crowded waters.
Old 07-06-2012, 07:24 PM
Corley's Avatar
Corley Corley is online now
epoxy coated
Rep: 622 Posts: 1,674
On a very small boat like your proposing a tacking proa is easy to do just put a net on a rack on the side without a float like the production ninja pro shown in the following video. You sail the boat like an Atlantic proa on one tack and a Pacific proa on the other.
Multihull Yacht Club of Victoria
http://mycv-news.blogspot.com.au
blog/projects http://trimaranproject.blogspot.com.au/
Old 07-06-2012, 07:35 PM
Doug Lord's Avatar
Flight Ready
Corley, I saved the website for this boat and their trimaran but twice now when I clicked on it, it froze my computer! Good call to post the video...
Old 07-06-2012, 09:32 PM
Rep: 10 Posts: 17
I do have trimaran experience--been sailing mine for--oh--ten years or more. Been in others occasionally too. Its proas that I'm not experienced with.
The ninja in the video Corley posted is very like what I had in mind if I didn't make a full trimaran, thanks much Corley.
Back to my question about proas--does anyone have experience with a tacking proa and know if the type of proa in the video tacks as well and easily as if it were a trimaran?
Either way I plan on smaller type amas that don't allow the main hull to fly--I don't want the weight and moment penalty of the larger amas and stronger xbeams--remember, as I said earlier I need good maneuverability. Of course speed is another issue--I'd guess the proa version might be a bit faster--higher SA/D.
Thanks for all the comments!
Old 07-07-2012, 01:44 AM
That is an outrigger in the video, not a proa. check out the Malibu outrigger pages for comparisons. a true proa is double ended and travels in both directions.
Old 07-07-2012, 04:58 AM
Corley's Avatar
epoxy coated
There is an article on proafile about the ninja pro they also consider it an outrigger from the purist angle. Interestingly enough the original render included a bruce foil (not included in the final design).
http://proafile.com/archive/article/238
Old 07-07-2012, 07:51 AM
Rep: 10 Posts: 17
I appreciate all the advice. I can understand calling the ninja an outrigger rather than true proa. Nomenclature is often a problem--it has always bugged me that every double-paddle boat under the sun is referred to as a kayak although they vary widely in purpose and design.
In the ninja video it certainly looks like it can move in light wind, but he sure took his time coming about, even for such light wind. I will have to think about a roller-furling genoa, except that I do wish to keep things very lightweight and simple. I prefer a double-sheeted jib--it can even be big enough for some overlap. I know I do not want a heavy boat with a lot of unnecessary gear--in my mind better to go simpler and lose any weight I can--perhaps my penguin background speaking.
So many choices. I'll have to decide in the next month or two if I want to start building this winter.
Old 07-07-2012, 10:56 PM
oldsailor7's Avatar
oldsailor7 oldsailor7 is offline
Rep: 360 Posts: 1,477
"Another way of phrasing it: Is the second ama worth it?"
Perhaps I am opinionated, but IMHO the answer is YES.
Tri's rule. Yay.
Old 07-07-2012, 11:29 PM
I heard some of the Brits came up to Newick a few years after Cheers took 3rd in the OSTAR and told him that he'd put one over on them because they'd been trying and nobody had been successful since.
I think they have a place though. They certainly are interesting in how many variations there can be just in the rig, leeway, steering basics.
Old 07-08-2012, 01:57 AM
HASYB HASYB is offline
Rep: 139 Posts: 225
I always found the the plans of Chris White's Dragonfly very appealing, don't know if he still sells them though cause they're not at his website anymore.
http://www.chriswhitedesigns.com/
Laws alone can not secure freedom of expression; in order that every man present his views without penalty there must be spirit of tolerance in the entire population.
Albert Einstein
Canters tacking usa2 Sailboats 19 07-11-2010 09:10 PM
'Self tacking' daggerboard? kerinin Multihulls 12 06-21-2009 06:28 PM
Self tacking jib Paul Scott Sailboats 34 08-07-2008 06:11 AM
Trimaran - tacking probelm Sailingpeanut Multihulls 8 08-10-2007 03:53 AM
self tacking jib roach Pieetry Sailboats 0 07-24-2003 03:25 PM
