Old 10-26-2009, 06:04 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,600
Proven benefits from windsurfers to Hydroptere-do it if it doesn't add too much complexity at your size. Cool thing about a monofoiler is that veal heel does that and a lot more including a big increase(20%) in RM for "free".
Look forward to more about your project!
yes, it is a revolution
Old 10-26-2009, 08:07 PM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
Originally Posted by waynemarlow View Post
...What are the pitfalls of outer facing foils ?
The side force and the coupling with leeway goes the wrong way.
If you generate vertical lift on the leeward foil, the sideways component is directed to leeward. Some other foil will be needed to oppose the side force from the sails, and it will have to carry a higher load than normal.
When a gust hits and increases the leeway angle, the vertical lift will decrease due to the leeway reducing the angle of attack of the foil. This will cause the boat to roll to leeward - just what you don't want at that time.
Tom Speer
Old 10-26-2009, 08:31 PM
Rep: 457 Posts: 1,404
Tom is correct about the to leeward shift - but I found, even in some savage gusts, with the boat sailing at speed, the lee float and foil never buried further than a few cms. below the float rocker - so outward slopers do work. One important advantage of outgoers is that the main beam/beams can be reduced in length - the foil creates a longer overall beam, therefore lighter platform because of less material. The opposite occurs with conventional in slopers, beam reduces with lift off, as does stability. That is why l'Hydroptere is 80 feet wide by 60 length. Having said all this, I've changed to inverted Y's.
Old 10-26-2009, 08:39 PM
Doug Lord's Avatar
Flight Ready
Gary, have you ever sailed your boat(w/"outgoers") upwind against another boat that was fast enough for you to judge the upwind ability of your boat?
Old 10-26-2009, 09:30 PM
Doug, was excellent to windward, couldn't see any difference in pointing ability - but then my wing mast rig is clean and efficient and that might help. In light airs, larger keelboats (where they're at their best) could outpoint me by a few degrees - but Groucho was always faster - pretty normal for multihulls. You could point as high as the keelers but your speed was down and they moved away, let the boat sail itself, pretty soon you were ahead of fleet. Remember Groucho has a main hull dagger, not relying on entirely on foils for countering leeway. Without dagger, not good windward performance, definitely went skidding. But then that was the same with inward slopers too.
Old 10-26-2009, 09:36 PM
Doug Lord's Avatar
Flight Ready
Thanks Gary. Did the dagger rotate(change angle of incidence from tack to tack) or was it fixed?
Old 10-26-2009, 09:45 PM
Bit more useless information - used to sail a Newick 36 Mokihi with angled in 40 degree foils. Winning Coastal Classic one year it was beat in 5 knot airs from Cape Brett to Russell - we pushed the main hull dagger down to its limit, leeward float foil down too, and just walked away from the closest competitors, multis and much larger keelers, no one could touch us and we could hardly see them astern at Tapeka - that main dagger is very important on a foiler.
Old 10-26-2009, 09:47 PM
Dagger fixed.
Old 10-27-2009, 05:29 AM
waynemarlow waynemarlow is offline
Rep: 72 Posts: 96
Surely as both windward and leeward foils are creating lift in opposite directions, the windward foil must be generating lift toward the windward countering the leeward foil ?
I need to have a flat downward foil of some kind at each end of the foils to prevent " beaching " damage, I had thought perhaps like the winglets used on gliders and aircraft, perhaps these would have enough area to act as leeward stabilisers.
Best shape for surface piercing foil grob Sailboats 48 11-23-2010 04:47 PM
efficiency of surface drives and surface piercing propellers David Knight Powerboats 7 09-24-2009 04:10 PM
surface piercing propellers seyyed1349 Boat Design 13 02-18-2006 02:42 AM
Surface piercing propeller characteristics manunk Boat Design 3 06-28-2005 02:12 PM
Surface Piercing Props gyrojocky Props 22 12-10-2004 07:50 PM
