| Starting my Quattro 16 from Woods design Dear all, I decide it, I start the construction of my Quattro 16. I will face some difficulties, the first one is that I´m not leaving in my own country (I'm in Mexico in a small island called "Ciudad del Carmen"), so I don´t have all the contacts, shops and so on to find all the supplies, and also friends with experience who can help me. Second, I will need to import a lots of things from USA, and that take long. After studying all the information provide by Woods, my first question is: What is COLLODIAL SILICA? How do you use it? What is his purpose? I couldn't find in the plan where to use it, but it appear in the material list.I will, of course, give you the advance of the project via this Forum and post photos. Thanks in advance for any help provided. Patrick |
| Colloidal silica is mixed with epoxy to thicken it for gluing or for forming fillets. I've successfully used 600 mesh silica from a pottery supply company-- much cheaper, and seems to work well enough. |
| Cotton flock too Gday You need two types of additive for your build. One will be high strength and medium density - silica - I use one called Cabosil. It is for turning clear epoxy into a glue. It is good for high strength fillets and gluing. The other additive is microballoons. This is low strength lightweight filler for fairing - smoothing out the hul or deck. cheers Phil Thompson |
| Hi guys, i do the same - nice to know that we even use the same terminology Quote:
| Congratulations Patrick, I hope the build is very rewarding and the sailing even more rewarding. Please keep us posted as you progress. Kevin |
| Most fillets don't need extra strength if they are on inside boxed corners. If one thinks there is a chance that the joint will flex a lot then I use cloth over the wet fillet. The various glass and cotton fibers give poor volume for a given amount of epoxy, same is true with the nice to use woodflour. That means more cost and weight in your boat. I use at least three components at various times: - A medium balloon like phenolic or Q-cell, mixed 3-4 parts Q to one part cab. I mix as much of this as I can into the epoxy without drying it out. Do overmix it at times so you really know how much you can add, because it is a lot. I use only as much cab in this mix as is required to keep the fillets from slumping, less cab means more yield and liighter weight. This can vary depending on what you are applying it to, and the weather. - I use cab alone for certain gluing jobs. - I use microlite for fairing. The only thing that compares to microlight in sanding ease and feathering out is talc which is too heavy. At least that I have tried. |
| Patrick, Look on the raka.com site in florida, they have good info on the various fillers. |
| Selecting a good design before starting... | GrumpyTim | Metal Boat Building | 4 | 09-17-2008 06:02 PM |
| Woods Sango | Meanz Beanz | Multihulls | 4 | 02-14-2008 12:45 PM |
| Starting out in Boat Design | AstroTux | Multihulls | 6 | 07-21-2006 11:52 AM |
| Starting out in Performance Powerboat Design | Archive | Education | 5 | 01-25-2002 07:47 AM |
| Using Different Woods | Archive | Wooden Boat Building and Restoration | 1 | 06-12-2001 03:55 AM |
