Old 06-03-2010, 04:35 PM
SpiritWolf15x's Avatar
SpiritWolf15x SpiritWolf15x is offline
Rep: 10 Posts: 51
Originally Posted by cavalier mk2 View Post
They charge too much for the crane down here. Since you've got to splice the mast you might want to rework the step and heel.
We've always raised our mast from the front towards the back, using the main sheet to bring it up.
I'm going to see if the mast section I have now can be hacked up to make a sleeve.
Old 06-03-2010, 06:11 PM
Motivator-1 Motivator-1 is offline
Rep: 10 Posts: 50
I can help
I was a partner in a Mast Fabrication company in Florida for several years. I can help you with splicing your mast sections, but I will not be able to do it here in a post, as it is a technical process. If you email me, I will get into contact with you and be happy to explain some of the techniques including Tapering the top of the mast, and even some hints on Masthead construction.
Regards,
John
Splicing in a new masthead kreitz Sailboats 10 12-19-2008 08:45 PM
Splicing and soldering off ground wire? Brylk1830 OnBoard Electronics & Controls 8 04-19-2008 11:02 AM
Scarfing, Splicing, join for Ply gary1 Fiberglass and Composite Boat Building 16 11-29-2007 11:50 PM
mast design-how do you go upon calculating the effect of the sail on the mast??? airturb Sailboats 34 02-21-2005 09:55 AM
Mast Splicing? ClarkT Sailboats 4 07-09-2003 07:14 PM
