#46
| Are you sure, WIIG uses a LIFTING airfoil, but last I heard these thing use DOWNTHRUST airfoils, to keep the "boats" from flying up & doing flips. (similar to the F1 cars mentioned earlier in this thread) |
#47
Have you heard of Mirabaud? It is a monohull foiler with the entire structure made of carbon tubes. The 26' hull was cut from a cat hull and is just a shell. I've talked to Thomas Jundt,the developer and one thing they have considered is fabric skins down the line. As to foils: the boat has to be very carefully designed or there will be little if any gain. Cats,so far, have not been ideal foil platforms for sailing -monohulls and tri's seem better suited. http://www2.jundt.ch/blog/ |
#48
Above is the portion of the post to which I was responding. There are very clear examples of planing craft (and these are planing craft whenever their hulls touch the surface at any speed beyond a slow crawl) in response to the posted comment. I used to photograph these boats as a part of my photography career back in the seventies along with cars and motorcycles and have spent a very long time watching how they work at different speeds around a course. I get that they utilize WIIG technology for a good deal of their ability to attain such high velocities, but at much of the lower speeds, which they do see frequently in a race, they are purely planing. The foil in the water from the port hull form is specifically to hold the boat when they turn left. Without the fin, they would quickly skate away into the bank of the river, or do a rather spectacular capsize flip as the starboard hull caught an edge. When you see great amounts of spray off the transom, it's all because that part of the boat is riding on the surface. If they were totally supported as WIIG craft, then the disturbance would be limited to pure prop effect and nothing more. When they are doing their taxi out to and back from the course, there is a lot of wetted surface, as has been suggested. However, the same is true for Hydrop whenever it is off the foils, so I truly do not see the point of that particular comment. The photos illustrate that absolute minimal planing surface contact at quite outrageous speeds is not only safe, but it is well within the realm of a properly handled craft. Not only do they go in straight lines, but they make 180 degree turns on a race course while changing lines for competitive purposes. You can’t maintain that kind of handling at speed from a relentlessly evil boat. The underbody provides the lift on these boats in the fashion that Gary indicated and they do have downforce surfaces in order to keep the boat in balance while under way. The downforce foils (especially the forward surface in front of the cockpit) on many of the boats can be tuned while underway in order to adjust the proper force for different speeds. These are very complex craft to operate, much like Hydrop. The reward, just like Hydrop, is a maximization of available power when compared to the minimization of the drag signature. Perhaps a relaxing of the thoughts on the topic would allow for the consideration of the technology as it applies to the conversation. I get that engine driven boats are not for everyone and these are particularly powerful engines, but many of the same issues are present, albeit at much greater speeds. There's a reason why they are called "HYDROPLANES" and not HydroWIIG's, or Hydrofoils. And yes, Rob.... they do occasionally crash, as does Hydrop and all high end racing machines of every kind. Sadly, it's really the only way to find out just where the limits exist for any particular setup and the boys (and some gals) are pushing the envelope whenever they can. There's no such thing as a successful race driver who practices consistent, conservative tactics. If taking it slow is one's MO, then that driver is quickly shown the door and thanked for their time. |
#49
Just a heads up: Hydroptere uses two surface piercing foils forward and an inverted T foil on the rudder. The two main(surface piercing) foils are not "ladder foils" but are single tapered foils with fences along the span to prevent ventilation. -See the picture below of the Baker/Navy Monitor-the first sailing monofoiler. Note that it has ladder foils. |
#50
| Interesting Doug..I hadn't translated the site yet (my French is a bit fuzzy), and was going based on visual observation of the foils & the craft in motion...looked like ladder-foils to me (and yes, I did notice that they were angled like surface-piercers, and I saw that the rudder was an inverted "T" as well, but it doesn't seem to be suppoerting much weight...primarily just steering & maintaining attitude, I think. |
#51
Lots to learn here, to be sure. |
#52
These are just 2 different ways to discribe it, you cannot add those effects up. Also the high pressure on lower surface is limited by sum of ambient pressure at some depth below surface + dynamic pressure. This is equally valid for both foils and planing surfaces. At the max pressure the speed of water flow is brought down to zero related to the surface, also called as stagnation pressure. There is no way to exceed that limit. And at high speeds both foils and planing surface can be reasonably close to that condition. (less than 50% off at average pressure on lower surface) That means same platform areas produce same max force on lower surface. No advantages on either foils or planing surfaces. But since planing surface has less than 50% wetted area, the foil would need same pressure difference between ambient preesure and upper surface pressure to compensate. This is not possible at high speeds when it requires negative absolute pressures. Therefore max CL available drops in those conditions as cavitation limit hits in. When a foil is operating at low speeds and optimum L/D the suction side has typically 2-times the pressure difference related to ambient compared to the high pressure side (=lower surface on foils) At high speeds the cavitation pressure limit reverses the situation and L/D drops. Lets try an example: speed 50 m/s, dynamic pressure=1275 kiloPascals = 13 atm. If the foil is just 1m below surface the ambient pressure is 1.1 atm Max pressure at stagnation is 14.1 atm and minimum practical pressure near cavitation 0.1 atm. Max peak pressure difference for foil is therefore 14 atm. High pressure side produces 13 atm and low pressure side (top surface) just 1 atm or just 7% of total. Clearly much less than typical 67% at slower speeds. If the average pressure difference for the foil is 10 atm, then Cl can be calculated as 10atm/13atm = 0.77 To produce the same lift force the planing surface with twice the planform area only would need 5atm pressure difference over ambient 1atm at the surface. In practise it can have at least 8atm allowing less area and less wetted area as a result. Quote:
Skip the lift/area requirement and only use beter L/D and it becomes much easier task for the foil at the same limited range of speeds. Quote:
Further more old YPE (Yellow pages Endevour) used planing surfaces and acheaved beter Vboat / Truewind ratios than hydroptere does. Same for the newer version. That's a good indication on L/D differencies. Like I alredy said the real advantage of foils over planing is when they have to cope with some seaway. No sailing planing craft is likely to compete with Hydroptere in such case succesfully. Hydroptere also adjusts it wetted area with different speeds and is closer to optimum than planing surface is likely to have with same requirements on wide speed range. But at optimum operating point it loses on optimized planing craft like YPE on L/D. |
#53
If the rudder foil were supporting any more weight with the starboard foil flying than with both forward foils immersed, then there would be a notable difference in the craft's pitch when this happens, and I haven't seen that happen in any of their videos, nor in this picture (think of the balance issues that would cause). |
#54
Deflected mass: Inertia from watermass imparted to foil as lift when water is deflected downwards These are two VERY SEPARATE forms of lift, please try not to confuse them as they will MOST DEFINITELY affect the accuracy of your equations if you leave one out. The difference between these two forces is the difference between flying a flat plane, and flying an airfoil....otherwise aircraft wouldn't use airfoil-shaped wings, as the exact same effect could be had without the design constraints needed to take advantage of Bernoulli's principle. |
#55
| robherc, another picture of the "space frame" foiler above(from the Mirabaud thread under "sailboats"). This thing has the same W(weight in pounds)/SA(in sq.ft.) as the 11' Moth! : |
#56
If you were correct Newton's law would not apply to foils, the idea is obviously completely wrong. Same for Bernoullis law. Same for principle known as conservation of momentum. Quote:
Having any accuracy in lift calcs requires Bernoullis law and newtons law to have exactly the same lift as a result. |
| deck beams query | lazeyjack | Software | 2 | 04-15-2007 06:41 PM |
| picture of main frames and webframes of ship | pavel915 | Boat Design | 0 | 02-05-2007 01:28 AM |
| Roof beams | TONY B | Wooden Boat Building and Restoration | 0 | 06-06-2006 09:23 PM |
| Modelling composite beams in Ansys | fencer | Boat Design | 0 | 02-27-2006 02:41 AM |
| Flooring beams material? | jameshogan | Materials | 9 | 03-04-2005 01:51 AM |
