Old 11-18-2010, 09:49 PM
rayaldridge's Avatar
Rep: 322 Posts: 581
Small trailerable cruising cats... biggest flaw?
In my opinion, it's the difficulty of folding them in a way that is as simple and fast as folding small trimarans.
A number of ingenious solutions have been tried. Among the best are Richard Woods' cats that have all accommodation in the center deck, and fold the hulls under that deck for trailering. It's a great solution, especially considering his out-of-the-box solution to ergonomic comfort at anchor-- his drop floor.
My objections to that approach might not matter to lots of folks, but I would prefer a solution that didn't involve tipping the hulls over, and that preserved the open bridge deck, which in very small cats is really nice to have, for a deck tent that can greatly expand the interior at anchor. I'd like to have all accommodations in the hulls, for lower profile and wind resistance, while still retaining sitting headroom below. I'd also like a solution that allowed the boat to be folded on the water, so it could be kept in a narrow slip. Lastly would be a way to fold the cat without having to lower the mast, so that unfolding to sailing beam was a matter of a couple minutes, instead of the hours it generally takes most trailerable cats that fold or demount.
All these problems have long since been solved for trimarans. Cats are a more difficult engineering problem, I think, but I wonder what progress can be made?
Ray
http://slidercat.com/blog/wordpress
Old 11-30-2010, 09:13 AM
SerjKu SerjKu is offline
Rep: 30 Posts: 7
If to contemplate this problem on an example of projects R. Woods it is possible to tell that Wizard and Sango are easily turned off. But they look not so attractively (UMHO). Merlin, Strider, Skua look much better (UMHO). But for this purpose that they would be convenient in transportation and deployment, extras are necessary.
And it simply catamaran of my acquaintance
P.S. I am sorry for my bad English.
Small trailerable cruising cats... biggest flaw?-1440.jpg  Small trailerable cruising cats... biggest flaw?-1441.jpg  Small trailerable cruising cats... biggest flaw?-1453.jpg
Small trailerable cruising cats... biggest flaw?-expedition019.jpg  Small trailerable cruising cats... biggest flaw?-1457.jpg  Small trailerable cruising cats... biggest flaw?-1226668497.jpg
Old 11-30-2010, 02:16 PM
4sail 4sail is offline
Rep: 10 Posts: 6
A great looking trailerable catamaran, SerjKu. Do you any information that can be posted?
Old 11-30-2010, 03:10 PM
Rep: 322 Posts: 581
Yes, I'd be interested in knowing how it folds.
I don't think my list of design goals is unreasonable, but I can't seem to find a design that fulfills that list.
Ray
Old 11-30-2010, 06:02 PM
AnalogKid AnalogKid is offline
Rep: 10 Posts: 26
Ray, have you looked at how some of the Wharram owners launch their trailerable-sized Tikis?
The beams are retained in tubular sockets on the deck of each hull. On the trailer, small 'dummy' beams are inserted to keep the hulls upright and together. Once launched, the front and rear beams are replaced with the full-length sailing beams while the centre 'dummy' beam is retained. The full-length beams are lashed at one end while a line with double purchase is used to drag one hull to the far end of the beams. Once the front and rear beams are lashed at both ends, the centre beam is also replaced.
Obviously no deck is in place while all this goes on, the deck boards being sectional and put in place after the boat is 'expanded'. But what if the open deck could be made to concertina down between the hulls in the folded position?
Old 11-30-2010, 06:35 PM
Steve W Steve W is offline
Rep: 360 Posts: 686
Analog,what you describe is much the same system that was used on my Macgregor 36,i built a telescoping trailer that allowed it to all happen on the trailer,it is however more of a transportable cat rather than a trailer sailer
Ray, Roger Simpson had a design for a folding cat that used ladder style crossbeams that had some depth and hinged in the middle and at the hulls,i think the center of the aft beam went aft and the mast beam went fwd,the tramp stayed laced to the hulls and there was a solid link bar that connected the beams together in the center.The boat was about 24ft i think. I dont know if the design is still available.
Steve.
Old 11-30-2010, 07:10 PM
Rep: 322 Posts: 581
Analog-- that was sort of the same system as my old Wharram Tane, except that the old system was a lot less convenient. There were transport beams and sailing beams, and these had to be switched after launch. What made it worse was that there were two forebeams joined by a slat deck, and two aft beams, also with attached deck. Even when I was young and strong that was a pain to manhandle. I had to lash temporary 2X4 beams to the gunwales to keep the hulls from tipping over when they were freed from the transport beams. It took half a day to launch the boat, and it wasn't any fun.
Steve, the Simpson design sounds a bit like something I'm considering. Do you know how the hinges were reinforced to take strain? I'll try to look up the design. Simpson seems to have been sort of an unrecognized and under-regarded pioneer.
Ray
Old 11-30-2010, 11:45 PM
Rep: 30 Posts: 7
http://www.catamaran-ivan.ru/
Old 12-01-2010, 02:39 AM
Rep: 30 Posts: 7
I the сatamarano-dreamer, but at me "a hole in a pocket".
Small trailerable cruising cats... biggest flaw?-1005.001.jpg  Small trailerable cruising cats... biggest flaw?-1005.002..jpg  Small trailerable cruising cats... biggest flaw?-1005.003..jpg
Small trailerable cruising cats... biggest flaw?-1005.004..jpg  Small trailerable cruising cats... biggest flaw?-1005.005..jpg  Small trailerable cruising cats... biggest flaw?-1005.006..jpg
Old 12-01-2010, 09:57 AM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
Here is one as well:
http://www.multihulldesigns.com/desi...becatslide.htm
Kurt Hughes was right about this place.
Old 12-01-2010, 10:08 AM
Rep: 360 Posts: 686
Ray,The Simpson design im thinking of was called the Takeaway and was designed in partnership with an Alan Dowd,na. The beams are trussed metal and look like they are at least a foot and probably have full height pins,3 per beam.
Steve.
Old 12-01-2010, 12:58 PM
jamez jamez is offline
Rep: 184 Posts: 272
Steve.
I enquired about this design some years ago, was told (by Boatcraft) only one was built at that time (early 2000s iirc). from the study plans i have the hulls are quite roomy, for a 24' cat, and flared so the waterline is relatively narrow - sort of like a scaled down Backslash. The folding mechanism/beams are welded aluminium. You could check with Boatcraft Pacific for plans availability.
Small trailerable cruising cats... biggest flaw?-1_3.jpg  Small trailerable cruising cats... biggest flaw?-7_2.jpg  Small trailerable cruising cats... biggest flaw?-ta-7.3.jpg
Old 12-01-2010, 01:51 PM
Rep: 322 Posts: 581
Thanks much, guys-- very useful information. Massive-looking weldments on the Simpson-- ought to be plenty strong.
The boat I'm drawing now is intended for simple amateur construction (I'm a simple-minded amateur.) It's 19 feet 8 inches, and should weigh 800 lbs on the trailer. The idea was to come up with a design with more sailing beam than a Jarcat or other small fixed-beam cats, so a recycled beach cat rig would drive it adequately and safely, and a compact car could pull it. I probably need to use a slightly different approach. I'm trying to figure out a variant on the same approach Simpson used, but with wood and epoxy. Also, that approach, at least as shown, doesn't allow you to keep the mast up when folded, unless I'm misunderstanding the pics and drawing. That's a tough nut to crack, especially with the rotating mast I plan to use. But great food for thought. I really appreciate you guys going to the trouble of posting the info-- it definitely helps me.
SerjKu, what a fine-looking cat! I like the central pod for the motor. Looks very fast, but I was impressed at how dry the boat seemed to be, even in that heavy air. Nice!
Ray
Old 12-01-2010, 04:30 PM
Rep: 10 Posts: 26
How about building the folding mechanism strong enough to keep the hulls upright on a mooring, then 'reinforcing' them with additional inverted U-section beams slipped over the top and pinned in place. It would allow the hinges to be built on a more managable scale.
To my mind, the hardest part in this exercise is figuring out how the deck is to be folded or stowed and then replaced when going to and from narrow-beam format.
Old 12-01-2010, 05:17 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
You can look at 'cattofold' as well
http://www.cat2fold.com/
One of my designes has the front and rear beam one end each attached on a pivot so that both beams can swing into the length of the boat, but it requires flat-ish hulls.
Regards
Fanie
Water ! Just gimme water !
European Designers of Small Cruising Powerboats rsmartin Boat Design 0 08-13-2010 10:54 PM
Best Design for Minimalist Trailerable Coastal Cruising Chris Ostlind Boat Design 83 09-13-2009 03:17 PM
Building small cruising catamaran terhohalme Multihulls 7 07-28-2008 01:43 PM
Wish list for cruising cats SURRYEQUIP Multihulls 1 03-14-2007 11:59 PM
Woods trailerable cats DennisRB Sailboats 3 09-24-2004 09:29 AM
