#151
| Here's some real world experience with an Oceanic lateen sail used on Pacific proas. These are sometimes called crab claws. http://homepages.paradise.net.nz/garyd/walap.html |
#152
There is a lot of interest in low aspect ratio foils in the aerospace industry. The facetmobile is a nice example of this.
__________________ http://janetcg32.blogspot.com |
#153
| I do have one of Marchaj's books -- Sail Performance, I think. It's a bit over my head, but I really enjoy reading it. Brilliant guy. I wish there were some way to objectively quantify the performance of my little "fansail," but for now all I have is my seat-of-the-pants experience. Does it outperform a similar sized crab claw? I'll probably never know. But I'm willing to bet that it sails closer to the wind. - Frank |
#154
Thanks for the article, it is very interesting detail about the "radical" hull. Pity there was no description of the rig - area, height, length of the "booms" or "yards" (I don't know the proper term). Was the hull representative of a working boat from the Marshals? Or was this designed as a racer? |
#155
| This was an Enewetak design and was a little different from most Marshallese models. The hull was very narrow and it carried less sail in proportion to its length than most. I have a 150 page PDF (6 Megs) I can send you describing the design and construction. gary.dierking (at) gmail.com Quote:
#156
| Gary, Thanks for the offer. Please send to upchurchmr@yahoo.com. I guess I didn't read well enough about this being Enewetakest. Marc |
#157
One of the things I read was the large angle of attack the low aspect foils can create lift with out stalling, it is an interesting feature. Its true a high aspect foil has a better lift/drag ratio, but maybe at a certain scale (smaller boats and planes) the angle of attack advantage outweighs the L/D loss in terms of overall performance, and especially upwind performance. At any rate I love your design! Even if a traditional rig would perform better, I would prefer your configuration because of it's ease of setup and tear down. A version of your rig would be great on an everglades challenge boat. Keep up the good work Frank! I enjoy reading about your experiments, thanks for sharing.
#158
| Rapscillion, Low aspect foils on a jet are only one part of what makes the high angle of attack work. Just fwd of the intersection of the wing and the fuselage is extremely critical to formation of a vortex that spreads out over the wing. For this you need a lot of power (jet engine). Sailboats have neither the geometry in front of the wing, nor the outside power to get what you are talking about. Poor application to a sailboat. B2 and B1 bombers have high aspect wings. But I still like the fan sail, except for adding more area in light wind. |
#159
| Just took the folder-boat out today for 3 hours. First really good shakedown with the new hull. Wind, weather, and water were all just perfect. I don't rate many sailing days a "10," but this was one of them. Cloudless sky, well, you know... The boat handles and rides like a dream with the new hull, and is really quick, but I found some unexpected weather helm on the way back. Not sure how I'll tackle that... Overall, I'd say that 90 sq ft of sail is just about perfect for this boat IF the sail is really optimized -- which this fan sail seems to be. I'd swear it pulls better on all points of sail than my 102 sq ft leg-o-mutton. This hull also comes about on a dime and jibes with zero drama. Once I get that weather helm straightened out, it might just be the perfect little tri! - Frank |
#160
| PS - and as I may have noted in an earlier post, both the folding aka-amas and the lowerable sail rig were inspired by the EC. Cheers - Frank |
#161
The stall angle at low speeds of the facetmobile is well within the apparrent wind speeds experienced by a multihull. You could be right though, maybe there is nothing there to gleen that would apply..
#162
| What, if I may ask, is the facetmobile? - Frank |
#163
| http://www.facetmobile.com/ It was rightly pointed out that jets and sailboats are very different animals. What I find interesting is the efficiency of this particular low aspect ratio airplane, as well as the low speed stall angle of plane. I saw the fx-4 when it was in Oshkosh.. and I was amazed how much it reminded me of the first generation stealth fighter. But what is even more interesting is the current experimental stealth planes follow the facet construction approach (cost savings) and are low aspect ratio wing forms.
#164
| Rapscallion, Thanks for the reference I had not seen this. He still has power to keep it flying at high angle of attack. High AOA also "always" means high drag. perhaps the low aspect would work for downwind - but we already know that. See Marchaj. What "current experimental stealth planes" are you talking about? |
#165
| Wow, what a totally cool airplane! I'm totally impressed! I'm not sure that anything from that plane translates meaningfully into anything I can do with a sail, but it's sure an amazing piece of technology in its own right. In any case, low aspect seems to work great downwind. And the small upwind advantage of high aspect sails evaporates very quickly and even becomes a liability as you turn farther away from the wind. - Frank |
