Originally Posted by champ0815 Ok, I see the topic has moved a little bit in an unexpected direction... .
Nevertheless, the sliding gunter is an interesting concept for a hybrid rigg between stayed and unstayed.
Am I right with the assumption, that the "sliding" refers to the gaff which is movable in vertical direction without changing its angle to the mast?
If so, I see the advantages for reefing, instant depowering in gust response and the availability of fore and lightwind sails.
Has anybody ventured in the direction of telescoping masts (where the "gaff" slides in the mast for reefing)? This seems to me the next step in this direction, solving the problem (if there is any) of gaff tension... . |
I am putting a telescopic wing mast on my current boat. Mast starts as soon as the infusion table is finished. A gunter is an option, but the track and attachment to the mast have to be very strong (can't just use a halyard as it falls away from the mast when reefed), and there is added turbulence behind the mast when it is lowered.
Originally Posted by champ0815 And to come back to my initial questions:
Since nobody challenged the feasibility of using boom height supported surf poles on small multis, what about the upscaling of this idea to larger boats? No advantages seen, neither in rigg maintenance nor in weight of an adequately designed mast (in contrast to a real free standing pole) or in support and compression loads on the beam of a cat? |
Small boats, it will work, but deck space will be inhibited, large boats you have large horizontal compression loads, lots of things to trip over, maintenance and replacement issues with the wires, and you still need a pretty substantial mast. Plus, you can't hoist, lower and reef on all points of sail.
Dryfeet,
What other information on the one ruddered cat did you want?
rob
