Old 11-14-2008, 03:08 AM
bill broome bill broome is offline
Rep: 48 Posts: 101
self steering
any one got pics or drawings of wind-vane self steerer suitable for a 7 metre cat?
lo-tech, hand-made, rugged, or at least pretty would be good.
Old 11-14-2008, 03:17 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
Other thread.. Self steering
Old 11-14-2008, 03:34 PM
Rep: 48 Posts: 101
thanks, but...
most of those guys have a metal fabrication shop, and spend too much time in it.
i like the bungy cord and jib sheet style, but it doesn't work off the wind.
so i'll build my own. if i get something that works, it'll be in living color here. may take a while though- very hard to get 'rugged' and 'sensitive' in the same 'rustic/primitive' implement...
meanwhile, if you see something with plywood, cords and miniblocks-
Old 11-15-2008, 03:55 AM
TeddyDiver's Avatar
Gollywobbler
A flap attached to stern rudder (just like in aeroplanes), small (pref aerofoiled) wing in a vertrical axel controlling the flap. Adjustment knob to turn the wing to desired position..
Old 11-15-2008, 04:47 AM
Rep: 48 Posts: 101
td, i have come across references to this technique, in high tech devices.
not certain why it works, as the aim is to correct the angle between the wind and the hull. i can imagine the hull pulling the rudder towards centerline through boatspeed, and thereby causing the vane to induce a turning impulse on the fin, so on the rudder. very indirect and maybe unresponsive, especially if you lose speed quickly.
on the other hand, fewer moving parts, not much friction- i'll try it out.
Old 11-15-2008, 06:22 AM
oldsailor7 oldsailor7 is offline
Rep: 253 Posts: 1,067
Having fiddled with all kinds of so called self steering devices over the years-----I only have one piece of advice.
Get an Auto Helm.
Old 11-15-2008, 07:37 AM
TeddyDiver's Avatar
Gollywobbler
Bill, changed wind direction turns the wing turning the flap to the same direction, which turns the rudder to opposite direction...
In shorthanded cruising it's more convenient to have both a windvane and an autohelm. They actually aren't compareble, other steering relatively to wind and other to a heading. Sometimes depending on the circumstances it's a huge difference
Old 11-15-2008, 04:41 PM
Thats a very good point, and it just depends on what you want to do.
For instance we sailed from Sydney to Lord Howe island on auto pilot the whole way.
The pilot held us to the most direct route. We adjusted the sails to suit as we went along.
As the wind backed we hardened up the sails. As the wind rose we reefed.
We ended up with a triple reefed main alone on a very close reach, with never an anxious moment. Average speed for the whole trip was 10.2 kts.
We were sailing a Spindrift 45 Catamaran, with three crew.
Old 11-16-2008, 04:13 AM
Rep: 48 Posts: 101
i am willing to believe a passive, wooden, device won't work as well as a well-fed 1st mate, but i can't feed a 1st mate so will have to aim for 'better than nothing.'
regards, bb
Old 11-17-2008, 12:59 PM
rayaldridge's Avatar
Rep: 292 Posts: 572
Bill, find a copy of John Letcher's book, Self-Steering for Sailing Craft. He devotes a lot of the book to home-made windvanes, and even shows sheet-to-tiller setups for sailing off the wind.
Whether or not such approaches will work for you is partly determined by how fast your boat is. Fast multihulls are generally not considered good candidates for windvanes, because the apparent wind can change so much in a puff.
Ray
http://slidercat.com/blog/wordpress
Old 11-18-2008, 04:24 PM
Rep: 660 Posts: 664
use Ebay
Hello Bill
For a 7 metre cat you would be far better served getting a small tiller pilot secondhand. Less money, less work and it will actually drive a multi.
cheers
Phil Thompson
Old 11-18-2008, 08:56 PM
dialdan dialdan is offline
Rep: 27 Posts: 40
Hi Bill
How about installing a trim tab on your rudder and then using a tiller pilot to drive the trim tab , they say it works a treat .
You can even use a morse cable to connect them ,which helps to keep the tiller pilot out of the weather
Al
Old 11-18-2008, 11:17 PM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
it does work to a certain degree in normal weather, it is when the going gets \rough that the full rudder is required, then the trim tabs units do bugger all, and it is then that you actually want it to work well, an extra pair of hands that does not fall asleep
Old 11-19-2008, 01:53 PM
garydierking garydierking is offline
Rep: 97 Posts: 71
Searunner steering vanes
The Jim Brown designed Searunner series of trimarans included the design for a self steering wind vane. During six years and 20,000 miles of Pacific cruising it performed beyond anything imaginable. Anything from 4 knots of wind with huge swells to surfing at 22 knots was never a problem. I never touched the wheel during all that time except to enter and leave a harbor.
I'm not sure what the key factor in its design was.
The large stern hung rudder (with a skeg under the hull) would respond instantly to the slightest movement of the trim tab. It never failed to fascinate me and I'd spend hours just watching it work. It was certainly the most valuable member of the crew.
Old 11-20-2008, 12:39 AM
farjoe farjoe is offline
Rep: 26 Posts: 112
the hinges at the bottom of the rudder and the tab must sure create a lot turbulence in that area.
Would such a system function for a semibalanced rudder with no skeg and the tab attached, perhaps more rigidly, to the back top of rudder and above only?
Would you need 2 tabs for the 2 rudders of a cat?
Self steering Manie B Boatbuilding 11 11-15-2008 12:25 AM
Steering shaun2222 Boat Design 3 04-30-2008 03:34 AM
cable steering skip7083 Wooden Boat Building and Restoration 1 03-18-2008 07:16 PM
Steering systems diazklm Powerboats 2 11-11-2005 04:03 AM
Self Steering Gear panthablue Sailboats 18 07-09-2005 07:59 AM
