| scaling applied to multihulls I am not seriously considering scaling up any designs in the near future, but after reading many posts about the scaling up of monohulls and the laws of "mechanical similitude" I got to wondering ...general consensus seems to be that, for the most part, a monohull can be safely lengthened by up to 10% without negative consequences, often gaining in stability. This can be done by simply increasing distance between station molds. Does this apply equally to a cat or tri? general consensus also seems to be that increasing the overall dimensions of a monohull shouldn't be done more than 2-3% if at all. Again, multihulls? |
| Whenever you change the overall dimensions by more than 10%, you need to re-engineer all the structure. That applies to multihulls too. For example, a 10' wave will be 100% of the length of a 10' hull but only 20% of a 50' hull. The stresses and handling are very different.
__________________ Gonzo |
| The laws of mechanical similitude apply to kitchen chairs, office desks, mutli hulls and everything else alike. |
| Resistance scaling | willfox | Sailboats | 6 | 11-07-2009 11:13 AM |
| Applied to Westlawn for the third time | Scottg4001 | Education | 1 | 01-23-2008 10:45 AM |
| Will Polyester resin eventually cure fully if applied below 60 degrees? | sbklf | Fiberglass and Composite Boat Building | 13 | 12-16-2007 03:48 PM |
| How are these wood preservatives applied? | Squidly-Diddly | Wooden Boat Building and Restoration | 0 | 10-21-2007 01:22 PM |
| Epoxy by Applied Poleramic | Guest | Boatbuilding | 0 | 04-16-2004 06:30 PM |
