Old 07-12-2009, 12:02 AM
driggers driggers is offline
Rep: 10 Posts: 4
Sailyak modifications: Rudder, side seats, stability
Hi there,
I'm new to this community and I recently bought a (pygmy) wooden kayak with a sail kit (a sailyak!). I've been sailing in it once and already I want to modify it. I'll tell the big picture in case anyone has good suggestions but I do have a few specific questions.
The sailyak is a trimaran, 17ft middle piece and about 10 foot long outriggers. It is about 10 feet wide.
Sailyak modifications: Rudder, side seats, stability-img_4336.jpg
I've got two pieces of 1x6 spruce that I will drill a couple of holes in and run them along the side of the kayak, attached to the cross beams. I and a smallish friend will sit on them with our feet in the cockpit. At the moment I plan to drill attach the spruce seats to the beams with rope and seal them with the WEST system (I'll read the product instructions and find the right one). They seem pretty resilliant but I was wondering:
Should I use fiberglass cloth on the spruce? Would this add a lot to their structural integrity?
The next thing is that I will need to add a tiller because my feet won't be on the pedals in the cockpit. However, after sailing this and sailing a dinghy, I noticed that the dinghy's rudder has a LOT of surface area and the dinghy turns on a dime, while I end up in irons tacking in good wind in my sailyak (maybe I wouldn't with more experience, but this is relative to the dinghy). The sailyak, piloted from the cockpit with a regular kayak, aluminum rudder, does not turn fast enough.
That said, I'm building a rudder out of plywood. I have two major things in mind:
1. I do not want to do irraperable to my boat or rudder by running it aground.
2. It needs to fit on the existing mount (see picture, it will be 6.5cm from pintle to pintle)
My ideas are as follows. One is pictured here
The other is to extend the existing rudder by drilling holes in it and bolting a piece of glassed plywood to the aft end of it (making obvious considerations for hydrodynamics). I can clamp a tiller to it too. My concern is that there will be more force on the extended rudder.
Sailyak modifications: Rudder, side seats, stability-img_4339.jpg
OK! next issue . You can see below, the way the beams attatch to the boat is a bit primitive and slow to set up. Any ideas would be good because I'm stumped.
Sailyak modifications: Rudder, side seats, stability-img_4338.jpg
Another Issue: Since I will sit on the side of a boat intended to be piloted from the cockpit, I risk making it awkward and unstable. Any thoughts?
LAST issue: The mast has no stabilizing cables and only a mainsail... on second thought I'm going to go look at rigging on other boats before asking this question (about adding a jib and some cables).
Thanks for helping out a newbie! I promise pictures and an account of my experience .
Alejandro
Sailyak modifications: Rudder, side seats, stability-img_4187.jpg
Old 07-18-2009, 06:51 PM
rayaldridge's Avatar
Rep: 292 Posts: 572
You could try a simple kick-up rudder like the ones I have on Slider, my little 16' cruising cat. My rudders just have a stock that the pintles attach to and a blade that rotates on a single bolt-- simple and so far, strong enough. There's a video here that shows it:
http://www.youtube.com/watch?v=1NBw4nRx6xI&feature=user
You won't need the elaborate system I have for raising and lowering the blades. But do drill the bolt and put a cotter ring through it to make sure you don't lose the nut and washer if it works loose.
As for lashing ideas, I just went through this with my next design, a little cartoppable cat. Here's the best idea I've come up with so far:
Because of the multiple purchase, you can get the lashings really tight, and because of the cleat, it's very quick.
Ray
http://slidercat.com/blog/wordpress
Kennedy Kraft 14ft - bench seats to pedestal seats is it worth it??? ChicagoPete Boat Design 4 03-22-2009 01:53 PM
one side plywood, one side fiberglass/epoxy, polystyrene core? murv Materials 4 05-18-2007 08:06 PM
Modifications... roeslerjd Boat Design 5 08-16-2006 08:02 PM
canting keels: how are they displaced from side to side? Thaddeus Boat Design 5 10-02-2005 05:22 PM
side by side centerboards? Ian Boat Design 8 01-02-2005 09:24 PM
