Do you think that using the base pressure is a good guide for adjusting Kdl to suit? I would expect that the base pressure is known ahead of time based on atmospheric pressure for the ventilated case and vapor pressure for the cavitating case. So at a given speed, there would be a target Cp for initial wake pressure.
Now that I think about it, a ventilated base bubble open to the atmosphere must have Cp=0 or nearly so. In reality, the bubble will assume whatever shape it has to in order to achieve this Cp=0 over its length.
The closest way to simulate such a bubble in XFOIL is to essentially turn off the wake viscous dissipation with a very large Kdl (I'm using 8.0 now), and shape the rear of the airfoil to get very nearly Cp=0 in the near wake.
I player around with this idea, and came up with the attached BV02. It's heavily based on transonic airfoil technology, with a deep center "spar" section with little loading, and loading in the front and back. The L/D is a ridiculously huge 20:1. This is even with a generous 6.8% thickness, and min(Cp) = -0.18, which should be good to 65 knots, or 80 knots with some modest sweep. Yowsah!
