Old 11-29-2011, 07:20 PM
sail102's Avatar
sail102 sail102 is offline
REBEL!!!!!!!
Rep: 42 Posts: 62
sail question
I have limited resources so I was wondering...if I could make a spinnaker and have my boat just have the spinnaker as the mainsail if the mast is 35 in and the spar is 2 ft.
Old 11-29-2011, 07:28 PM
Rep: 1493 Posts: 7,447
To start with, a 35 inch mast won't let you carry much sail. Secondly, a spinnaker is for downwind only; broad reach at most. If you only want to sail downwind, then it would work, but as a head sail. Mainsails are attached to the mast and that is not possible with a spinnaker.
Old 11-29-2011, 07:39 PM
sail102's Avatar
REBEL!!!!!!!
Rep: 42 Posts: 62
thx... well I was thinking about making a lateen rig with the mast being 2 ft and the spar being 35 in...would that work for a 5 ft catamaran?
Old 11-30-2011, 01:10 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
A lateen rig has three spars. The mast is one of them. The five foot catamaran must be a model or for use by small children. Otherwise it's questionable whether a boat so small should have two seperate hulls.
No one will be able to help you figure out sail area based on the length measurement alone. Length alone tells little about what kind of force would be required to move a hull along through the water. Displacement matters, intended use, and a multitude of lesser details, but no single factor such as length has much meaning alone.
Before asking a lot of basic questions here you should read a book about boat design (look up "Dave Gerr").
What is the boat intended to do?
Old 11-30-2011, 05:46 PM
sail102's Avatar
REBEL!!!!!!!
Rep: 42 Posts: 62
go on a lake
Old 11-30-2011, 10:04 PM
Will it go on a lake and be an RC?
Sail-less sail boat southbay Sailboats 10 12-03-2010 12:42 PM
Sail fast & Sail flat Parati Boat Design 38 11-22-2010 06:22 AM
Sail forces and sail plan ? fcfc Sailboats 63 06-13-2009 03:19 AM
sail Interiors-34' sail,wood strip comp. Roly Boat Design 2 02-05-2008 07:53 PM
What Sail To Use PsiPhi Sailboats 18 08-06-2007 07:44 AM
