Old 12-22-2011, 12:57 PM
Castle Castle is offline
rudder housing to trunk filler
I have a Tenant Chevron. The daggerboard broke off and struck the rudder housing. I have been trying to figure out how to make a new one. I still have the other one.
What would be a good filler between the outer fiberglass housing and the inner trunk? I thought high density pour foam might work, but I have reservations about it absorbing water. I read somewhere about epoxy and styrofoam beads but that seems like a lot of epoxy. Wood maybe?
Thanks
Old 12-23-2011, 11:10 AM
Rep: 3125 Posts: 9,403
Post some photos, so we can understand the nature of your repairs.
Old 12-23-2011, 08:41 PM
Steve W Steve W is offline
Rep: 360 Posts: 686
Are you talking about building a new daggerboard or rudder housing? its not clear to me from your post.
Steve.
Old 12-24-2011, 02:10 PM
jamez jamez is offline
Rep: 184 Posts: 272
Thanks
Amateur built chevrons use GBE foils. I can send you details from the GBE plans if you need them. If your Chevron is one of the production fibreglass ones the molds are in New Zealand. At one point the owner was interested in moulding and selling hulls/boats, he might possibly be interested in making you a board. Email or PM me and I'll send you an email addy for him.
Otherwise assuming the cases are elliptical, originally shaped around the boards like most Tennants the new board will have to be identical to the old in size/shape to fit properly.
Does the undamaged board fit both cases? If so you could use it to make a female mould (you only need one half) and lay up a new glass board or take some stations off it and use these to router or carve a new board blank out of wood and glass over.
Alternatively, assuming the equipment is available at your loc, might be to get a foam blank cnc machined slightly undersize from the other board, route a groove down the middle add carbon or glass uni's for longitudinal strength and glass over the lot.
Old 12-27-2011, 06:34 PM
outside the box outside the box is offline
Rep: 59 Posts: 92
If the moulds you are talking of for the Chevron in NZ are the ones to the one that is on the water at Lake Hood in Ashburton it is not a true Chevron apparently it is a modified GBE moulds were made from a modified GBE a Local chap did, a better boat than the Chevron apparently. Just for what it is worth have viewed the boat in above extensively at Lake Hood did not sail as Rig etc needs setting up properly first. Is still on the Lake as was down there a few weeks ago didn't look like it had moved from when I Last viewed it 12 months ago.
Old 01-02-2012, 09:16 PM
Rep: 184 Posts: 272
They sure are completely different boats. The glass version also being wider OA and having a bigger rig as well as the stylistic improvements. In either version the 1.2 wide hull gives a lot of room for a boat that size. According to Malcolm Tennant all the plans for amateur versions were sold overseas. I started trying to find info on the glass version in about 2000. Malcolm had no idea where the moulds were and Cresta Craft, the original builders told me they'd never heard of it . You will note their original ad shows the amateur version.
I spent 5 years looking for a glass one in NZ before giving up and buying a Wharram Hinemoa. I wanted a cat around that size (7 x 4 metres) and there wasn't a lot of choice.
rudder housing to trunk filler-img_0004-copy.jpg  rudder housing to trunk filler-img_0003-copy.jpg  rudder housing to trunk filler-img_0005-copy.jpg
Old 01-03-2012, 01:00 PM
Rep: 59 Posts: 92
JFWIW as stated the Glass Chevron (From Cresta Craft Moulds as in your advertising info) as it sits on Lake Hood Asburton NZ, as stated the glass moulds are available for use but royalties would still have to be paid to the original designer......
rudder housing to trunk filler-accelerator-1980s.jpg  rudder housing to trunk filler-cockpit.jpg  rudder housing to trunk filler-dscf1919.jpg
rudder housing to trunk filler-dscf1920.jpg  rudder housing to trunk filler-half-folded.jpg  rudder housing to trunk filler-just-launched.jpg
rudder housing to trunk filler-looking-bit-polished-new-antifoul.jpg  rudder housing to trunk filler-port-side-hull-front-berth.jpg  rudder housing to trunk filler-starboard-side-hill-fwd.jpg
Old 01-03-2012, 11:19 PM
Rep: 184 Posts: 272
Many thanks for the pics.
what is the difference between liquid filler and powder filler? yaasaay Materials 4 06-14-2011 05:14 PM
rudder trunk monjure Boat Design 1 12-28-2009 04:01 PM
Gimbal Housing Mark Emaus Sterndrives 5 09-27-2009 10:26 PM
Canting Keel Trunk Within a Trunk Idea Doug Lord Sailboats 20 10-06-2006 04:40 PM
panther jet housing pambarney Propulsion 2 06-29-2005 05:31 PM
