Old 04-11-2011, 02:05 PM
nickvonw nickvonw is offline
Rep: 10 Posts: 22
Round Bilge vs hard chine
OK, have been doing lots of research and was hoping someone could answer the following question
apart from aesthetics and building methods what advantages /disadvantages does a round bilge hull when compared to a hull with hard chines
cheer
yeeeoooooowww
nick
Old 04-11-2011, 02:14 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,598
cheer
yeeeoooooowww
nick
If you look at a narrow hull- and you compare two equal area sections a semicircular section will have less wetted surface but be slightly wider than a hard chine rectangular section. In the Moth class known for very narrow hulls(10/1-11/1) I was told by John Ilett that the skinnier hull was faster and that was why you see most moth hulls with hard chine square sections. Apparently, the reduction in wavemaking drag by being skinny trumps the reduction in wetted surface of the semi-circular hull.
yes, it is a revolution
Old 04-11-2011, 02:21 PM
Rep: 10 Posts: 22
thanks doug,
so why does round bilge seem to be more desirable??
is it purely asthetics??
nick
Old 04-11-2011, 02:29 PM
Doug Lord's Avatar
Flight Ready
thanks doug,
nick
There are a lot of factors-structural, aesthetic etc. Once you get into a L/B ratio above, say, 14/1 the advantage of the hard chine hull fades away and the semicircular works best.
Old 04-11-2011, 02:39 PM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Are we talking about powerboats or sailboats?
Old 04-11-2011, 03:00 PM
rayaldridge's Avatar
Rep: 322 Posts: 581
Round bilge is also easier to pop out of a mold, and is stiffer for the same scantlings.
Ray
http://slidercat.com/blog/wordpress
Old 04-11-2011, 03:14 PM
Richard Woods's Avatar
Richard Woods Richard Woods is offline
Woods Designs
Rep: 976 Posts: 691
You will find I have answered several of your questions on the FAQs page of my website
And, if you look at the Sango page (follow the link from the under 25ft designs page) you'll see how close a flat panel hull can be to a round bilge hull
If you are building your own boat I would be wary of building an over-curvaceous design. Filling/sanding is a soul-destroying time-consuming job for little noticeable performance gain. But if you are buying a production boat then, as Ray says, round bilge hulls tend to be stiffer and lighter, (as you don't have extra glass on the chine joints).
Whether building or buying I would avoid barrel shaped decks unless you and your crew are all very agile or you want a pure racing boat
www.sailingcatamarans.com
Old 04-11-2011, 03:39 PM
Petros Petros is offline
Rep: 889 Posts: 1,005
this has been answered many times on this forum. Similar size displacement hulls have little performance differences (expect perhaps in the most competitive racing only designs), on light weight planing hulls, hard chines allow it come up on plan faster and offer less drag when in planing mode, when in displacement mode the round bilge hull usually has less drag.
The choice is usually made on the basis of what is easier to build for the method used.
Old 04-11-2011, 07:13 PM
redreuben redreuben is offline
redreuben
Rep: 164 Posts: 352
There are no chines on a fish !
RR
Old 04-11-2011, 09:46 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
RR
...or on an apple!
-Tom
Old 04-11-2011, 10:37 PM
oldsailor7 oldsailor7 is offline
Rep: 269 Posts: 1,118
Round bottom hulls are obviously better because they have the lowest wetted surface and skin friction drag.
BUT.
The difference can be very little if the chined bottom closely resembles the round.
As proof of the pudding I took my chine bottomed Buccaneer 28 and glued on 2" slabs of foam, which I then sanded to a circular section and sheathed with glass/epoxy.
I was never able to discern any difference in the performance.
Old 04-11-2011, 10:49 PM
redreuben
Rep: 164 Posts: 352
Prob because the float is a sml proportion, if you had done the main hull too ? but you're right not worth the exercise if the boat is built.
RR.
Old 04-11-2011, 10:51 PM
RR.
That WAS the mainhull.
Old 04-11-2011, 11:12 PM
aka Terry Haines
Rep: 1814 Posts: 3,009
Round bilges reduce wetted surface area and what is called "skin drag" which is desirable if propulsive power is limited, as in a man-powered craft or a power boat designed for minimum fuel consumption. Hard chines assist a boat to plane. A hard chine boat is usually easier and quicker to build. There are many other considerations and it is a complicated swings-and-roundabouts thing. Performance usually catches most peoples attention, but the choice between hard chine and rounded bilge is one of the least significant performance factors.
Dances with Turkeys
Old 04-12-2011, 01:23 AM
Dean Smith Dean Smith is offline
Previous Member
Rep: 0 Posts: 0
Chime in different point of view
from a metal builders
In say a 14m yacht you will add a month(one man) for a round bilge build, a mere 160 man hrs
Not a radious chine mind you but a really nice forefoot, U shaped, and lovely lines
For this you can get, quiet upwind sailing, lovely looks and ADDED RESALE
Chines, yes in planing power boats
But in yachts , sailing, the hull form is terribly limited with chines
Round bilge or multiple hard chine on Sailing yacht ???? tang Sailboats 12 10-07-2007 04:15 PM
Square chine/round chine messabout Boat Design 6 03-15-2006 09:49 PM
Round v. Hard chine runabout hulls Sands Boat Design 5 01-24-2006 04:54 PM
round bilge vs chine jbard Boat Design 10 10-22-2005 10:16 AM
Opinions on round bilge vs hard chine Bassman Boat Design 5 02-21-2004 07:34 PM
