View Poll Results: Which rig is better
Bermuda rig 2 100.00%
Cutter/ketch combi 0 0%
Voters: 2. You may not vote on this poll
Old 03-29-2007, 02:48 AM
locofjok locofjok is offline
Which rig setup / sail configuration is better?
I’m currently considering to work a 40 feet Catamaran. It's suppose to be a boat with high comfort and easy handling - but also as good performance as possible.
I'm wondering which rig and sail configuration would be better.
I have attached a picture showing to different setups.
Which are the advantages and disadvantages in these two setup and which one would you recommend?
Thanks,
L.
Which rig setup / sail configuration is better?-two-rigs_2b.jpg
Old 04-01-2007, 08:12 AM
fhrussell's Avatar
fhrussell fhrussell is offline
Boatbuilder
Rep: 30 Posts: 135
Where's Brian Eiland?
One question..., where and how how do you attach the backstay(s) on the aft-mast configuration?
Old 04-01-2007, 05:27 PM
jamez jamez is offline
Rep: 184 Posts: 272
And presumably it sheets to the dinghy being towed behind :-).
Roy Chandler put a similar rig (but without the mizzen) on a bridgedeck cat based on a couple of Stilleto 30 hulls. It had a masthead roller furling genoa and a staysail on a boom. He also used a spinnaker off the wind. I've scanned the inside cover of his book which shows the rig.
Another option you might want to consider is a masthead cutter where the mast head genoa is essentially a light weather sail and the staysail is a sort of working jib. With both of them on furlers it gives quite efficient sail handling. Examples here http://www.easycatamarans.com.au/
Old 04-01-2007, 05:32 PM
Rep: 184 Posts: 272
I'll try that attachment gizmo again......
Which rig setup / sail configuration is better?-chandler-30.jpg
Old 04-02-2007, 06:13 AM
Rep: 700 Posts: 691
Why?
Being the designer of a folding catamaran and having a 38ft cat with a wishbone rig I am keen on innovation but I really don't see the need for the aft mast rig. The normal modern rig is very good, I prefer a small staysail for going to windward in 18knots plus when a modern cat needs slowing down to be comfortable.
Staysails, wishbones, fully battened mains and normal rigs and the like have all been proven. Putting an aft mast rig on a 40ft cat will cost lots of money and reduce resale. If you need to do it buy a Hobie 18 and try it on that. A web poll with people who haven't used the rig is probably not the best way.
I tend to not use the main going straight downwind and set a kite or reacher. The centre of effort of the rig is way forward and the boat is very placid to steer. Reaching or going upwind the main provides great lift and balance.
cheers
Phil Thompson
Sail Loading on Rig, Rig Loading on Vessel brian eiland Sailboats 93 02-23-2011 07:19 PM
St. Pierre Dory with junk sail rig Ian Booth Open Discussion: All Things Boats & Boating 31 07-29-2007 02:49 AM
New Balance Rig sail? Wellydeckhand Sailboats 3 04-29-2006 12:44 AM
Sail rig hardware? Kris Boatbuilding 3 04-13-2004 07:10 PM
Using EFI and marine setup vs. car setup curtis73 Powerboats 6 03-18-2002 12:45 PM
