Old 06-24-2011, 06:56 AM
Rep: 700 Posts: 691
Reverse engineering a Twiggy
In response to the thread on crossbeams I had a go at reverse engineering a Twiggy beam. Feel free to have a read and a comment.
Cheers
Phil
Old 06-24-2011, 08:59 AM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 205 Posts: 442
Nicely done. Steve
Old 06-24-2011, 12:38 PM
rayaldridge's Avatar
Rep: 322 Posts: 581
Very good stuff, Phil. Now if you could just do that for a good little cat...
Reading your piece did make me wonder why waterstays haven't generally been used to stabilize cat beams.
Ray
http://slidercat.com/blog/wordpress
Old 06-24-2011, 01:16 PM
bruceb bruceb is offline
Rep: 153 Posts: 565
Thanks for the post
Phil, thanks, that makes me feel better about my re-engineering my Buc 24, I have been coming up with similar numbers. I didn't realize the Twiggys had double water stays, are the attach points on the hull separated fore and aft? B
Old 06-24-2011, 03:40 PM
jamez jamez is offline
Rep: 184 Posts: 272
Great paper Phil. Plenty of Crowthers over here (NZ) but I've never seen a Twiggy, although Cathy Hawkins book gives some insight. Didn't know the beams had an option to fold.
Where the stays join the main hull near the waterline drag in waves may be an issue. Most designs for tube crossbeams seem to employ them (eg. Kurt Hughes, B24). The 25 foot tri I'm building (which has wooden box beams) has them running from the bottom of the hull step, normally well clear of the water. On my boat these are 6x50mm S/S flat bar, not a wire stay, so I suppose its technically a strut. I've seen a similar arrangement on a Bucc 33 with tube beams which I may have a photo of somewhere.
Old 06-24-2011, 04:25 PM
Rep: 322 Posts: 581
jamez I suppose a seagull striker is sort of an upside-down water stay. I guess I wouldn't be surprised to learn that some all-out weight-paring racing cats have similar strut and wire combos under the main beams.
Ray
Old 06-24-2011, 04:33 PM
Rep: 700 Posts: 691
Waterstays
Bruce - the Twiggy waterstays are about 200mm apart from each other.
Ray - I will dig out my reverse engineering of the Seawind 24 and write it up properly. It is a good little cat that has performed well and is solid too. It can use a dolphin striker to counter mast compression.
Jamez - the fold option was news to me until a few days ago. That's pretty sad considering I had my own plans that I sold with my Twiggy. I could do the calcs to prove the beams can't be cantilever but looking at them you can see that they aren't - they don't have increased depth at the root or any increased scantlings like a proper cantilever beam. I am sure that they are considered as compression struts only but need extra bulk to be walked on and take fore and aft loading - they are bigger fore and aft than deep - another giveaway for the compression strut.
cheers
Phil
Old 06-24-2011, 04:57 PM
Rep: 322 Posts: 581
Phil, I'm really looking forward to it!
Ray
Old 06-24-2011, 06:01 PM
langdon2 langdon2 is offline
Rep: 10 Posts: 24
Thanks for putting that up, Phil. Very interesting piece.
Cheers,
Steve
Old 06-25-2011, 04:41 PM
upchurchmr upchurchmr is offline
Rep: 224 Posts: 529
Ray,
All of the day sailing cats I have used have a dolphin striker. Same exact concept as a water stay just no main hull to get in the way of the loads. I thought you had talked about those in an earlier blog. Hobie 18's have a cable if I remember right and the Tornado in my back yard has an aluminum strap.
Marc
Old 07-01-2011, 04:50 AM
Samnz Samnz is offline
Rep: 42 Posts: 196
interesting
any chance you could share the scantilings for the foam and glass beam?
the 12 degree angle is the angle used for the diamonds on an alloy rig, no surprises he uses the same figure.
Old 07-01-2011, 05:21 AM
Rep: 700 Posts: 691
Foam
Gday Samnz
I can do a quick sketch up of the foam beam in a few days. At the moment I am doing my reverse engineering on the wooden beam.
cheers
Phil
BIO refit on Crowther Twiggy kistinie Multihulls 8 10-06-2011 12:59 AM
Reverse Engineering (conversions And Modifications) viking north Boat Design 303 02-11-2011 02:09 PM
Port Macquarie - twiggy? trimaran basil Multihulls 9 01-12-2011 04:39 PM
Twiggy and buccanear zigzag Boat Design 0 08-03-2007 08:10 PM
Reverse Engineering Guest Sailboats 9 03-10-2004 01:59 AM
