  #46
Old 09-09-2011, 12:25 AM
oldsailor7 oldsailor7 is offline
Rep: 269 Posts: 1,118
One of the designers (I think it was Jim Brown) lost his boat at dockside when they went ashore for a short errand and left the propane cook stove burning with a pan of potatoes. The potatoes boiled over and extinguished the cooker flame. The gas, being heavier than air started to fill up the bilge. When the gas level reached the fridge pilot light -----------------you get the picture.
  #47
Old 09-09-2011, 05:48 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
as most boats have, a gas cooking stove in a boat should have a thermal gaslock
when opening the gas no gas comes out, the thermostat takes a sec or two to warm up before the gas opens
same thing when fire blows out or whatever reason than the thermostat closes the gas
  #48
Old 09-09-2011, 06:35 AM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
Yipster's right.
That story is a very typical example of how accidents happen on boats. You almost always see several mistakes that, when combined, produce the disaster.
*There should have been a proper gas stove with thermal shutoff.
*You should NEVER leave any fire unattended
Kurt Hughes was right about this place.
  #49
Old 09-09-2011, 07:04 AM
Pehaps it's just me --- but I have never felt safe with a gas bottle aboard my boat. In all my past boats I have only had a two burner metho cooker.
Mind you, the biggest Tri I have personally owned was only a 28 footer.
I have sailed on many 40 ft Tris and 45ft Cats and they all had bottled gas.
I have sailed on monos up to 60ft, but they never seemed to do much cooking. As I remember the crews seemed to only eat peanut butter and jelly on Rye.
  #50
Old 09-09-2011, 11:29 AM
cavalier mk2 cavalier mk2 is online now
Rep: 118 Posts: 820
I was able to add a kerosene stove with oven on the weight saved by losing the propane and plumbing.....
  #51
Old 09-09-2011, 01:25 PM
yipster's Avatar
Since a few months I have my first spiritus stove you can use in and ouside
used once, kerosine same fuel? Safe and odorless inside? Advice?
  #52
Old 09-09-2011, 05:40 PM
Rep: 118 Posts: 820
The English name for kerosene is paraffin. Mine is a old unit, they are harder to find now but used to be common. A spirit stove might be what we call denatured alcohol such as what the non pressurized stoves by Origo use. They are the safest fuel stove but less efficient because of lower flame temperature. The fuel tends to be more expensive too. I have a portable stove/heater Origo that is safe indoors but the alcohol does put out water vapor so you have to choose your compromises. The kerosene stove doesn't have the explosion problems of propane and the fuel is cheap, there are very odor free fuels available that will also work in a traditional lantern.
  #53
Old 09-19-2011, 07:15 AM
yipster's Avatar
thanks and still have to check those fuels as i want my toast just right
Refrigeration vacuum pump for drying out GRP WHumphreys Fiberglass and Composite Boat Building 15 08-01-2009 06:47 AM
Can someone tell me what is happening to my gas wellcraft20 Gas Engines 13 06-02-2009 06:05 AM
refrigeration on a 42 ft steel yacht bigbear69 Sailboats 3 04-03-2009 01:04 PM
Hyd. Elec for a small Pontoon Mark Emaus Hybrid 0 01-14-2009 04:40 PM
Regulations covering installation of elec. fuel pump fanefarchris DIY Marinizing 2 04-11-2005 06:24 PM
