Old 02-02-2010, 09:34 AM
lane lane is offline
Rep: 10 Posts: 18
Recycling Hulls, Post Yours
I always hate to see old catamarans go to the junkyard.
Here is a pic of my "new" trimaran named "Tri Again". 18 feet of Hobie 18 main hull, with two 5M GCat hulls serving as amas. The boat trailers at 8.5ft beam and then telescopes to 16ft beam for sailing.
Now fully rigged with the Hobie 16 mast and ready for fitting the sails from a donor Hobie 16.
Lane
Old 02-02-2010, 06:06 PM
Corley Corley is online now
epoxy coated
Rep: 267 Posts: 427
I'd like to offer some old mosquito fibreglass hulls to someone who would like to build a tri conversion or simply want to rebuild an old mozzie they have a pretty average timber deck but the hulls are solid grp built by blocky the boatbuilder and look unburstable I'm keeping the rig as I still have a mozzie I sail but if anyone wants the hulls they are free to take I'm located in Melbourne, Vic, Australia please pm me if interested.
Old 02-03-2010, 09:53 AM
RHP's Avatar
RHP RHP is offline
Rep: 1073 Posts: 568
Lane, do the amas float at the same height as the main hull, they look taller?
Old 02-03-2010, 10:52 AM
Rep: 10 Posts: 18
Help needed. Biplane Rig for "Tri Again"?
RHP,
Good eye noticing the difference in hull penitration of the water. The outer hulls do have greater draft than the center hull. I always admired the G-Cat, and they truly knife through the water, without the need for a centerboard.
She sails a bit like a very beamy 16ft wide cat, and there is none of the typical rocking of the boat when on the hook. She sails flat and it takes an extremely high wind to get a hull (make that two hulls) out of the water.
The G-Cat 5M hulls were a gift from a teacher in Edinburg Tx. His wife was cleaning up the backyard and I got an email to come pick them up. The Hobie 18 hull came from a teacher in Houston area who also had a wife that was wanting her back yard back, another trip and my yard started resempling a "Used Sailboat Lot". I still have another H-18 hull left so I can always design another boat someday. Hopefully a good use for old hulls.
Question, I have two complete Hobie 16 rigs and am considering a biplane setup with one mast on each ama. Any suggestions?
Lane in Austin
Old 02-04-2010, 05:51 PM
Rep: 10 Posts: 18
Ugly Lonestar 16 trimaran
Per the attached pic, I am giving a four of July salute to the camera. This was the first trimaran I built. Mating a tired Lone Star 16 monohull under a telescoping Hobie 16. Beam was 14 ft with good acomodations in the center hull, and great tramps for sunbathing while underway.
The amas kept her sailing very upright, generating stresses that far exceeded the design limits of the Lone Star. Using the Hobie 16 rig, she was carrying 50% more sail than the Lone Star 16 was designed to carry, providing lots of speedy sailing.
Unfortunatly, in a blow, the rig ended up pulling the windward schroud out of the hull of the Lone Star and the center hull was scrapped. The Hobie 16 was reassymbled and given to budding sailors on Lake Travis outside Austin Tx.
Old 02-05-2010, 06:04 AM
RHP's Avatar
RHP RHP is offline
Originally Posted by lane View Post
RHP,
Lane in Austin
Dont ask me my friend there are folks far better qualified to answer than I.
Sounds exciting though, wish you the best of luck!
Old 02-09-2010, 02:22 PM
kim s kim s is offline
Rep: 42 Posts: 67
re-cycled huls
designed middle hull with an old Hurricane 5.9 bought for £300 with no main and split rudder.
Uses evrything bar the cross beams
Rudders remain on the Amas. and center boards. No rudder on main hull.
14.5 knotts with middle hull flying, hard on the wind (f4) smooth water just before the mainsail disintergrated
Recycling Hulls, Post Yours-kim-p8250952.jpg  Recycling Hulls, Post Yours-topshot.jpg
Old 02-16-2010, 01:52 AM
aussiebushman aussiebushman is offline
Innovator
Rep: 72 Posts: 102
Your Trimaran beams
Hi Kim,
Really interesting - well done. Your beams appear to be ply that fold down? Drawings or more pictures of this system would be good - I'm starting to build a Trinardo from Kjell Nielsen's lovely on-line plans and am soon to pick up an A Class Cat for use as the Amas. He uses telecopic tubes but all ideas for folding arrangements are being considered.
Cheers, Alan
Old 02-16-2010, 01:56 AM
Innovator
Rep: 72 Posts: 102
Kim
Sorry - forgot to ask how she handles with the rudders and centreboards on the amas. Would be great if I can do the same with the A Class rudders.
Moderator - apologies if I am hijacking this thread - happy to start a new one if you wish..
Alan
Old 02-16-2010, 02:17 AM
Rep: 42 Posts: 67
re-cycle
Hi Aussiebushman
I made them from fiberglass but they couod be very easily ply.
o be honest I am not sure I built them strong enough as I did not get much help on that bit from the designer (long story) they have not broken but do seem to flex a bit much for my liking.
Once I finished my Lively 28 re-build we will go back and re-engineer them.
I will try and find some photoes of the wings folded up. very simple design. very similar to the Farrier boats but just a simple bar from the water line (ish) up to approx 2/3rd along the beam . un bolt the inboard end, stand on the outer hull and try not to fall in when they swing in
good game--good game.
I dont normaly fold them once launched, as it lived on a mud berth, so left them out. usefull for launch and retreval, but it was still to wide for uk roads, so had to dismantle to take home, so in hind site, not really worth it to me. (aaagh the perfect 20/20 vision comes back. complely blind till then----LOL)
If you want to start this on another thread it might be a good idea.
Kim
Old 02-16-2010, 08:52 AM
Rep: 42 Posts: 67
Originally Posted by aussiebushman View Post
Kim
Alan
Sorry Alan--forgot to answer this question.
LIKE A DREAM
Tacks quicker than most monohulls. Feels like you steer the outer hull round the curve rather than dragging it. I have played with acherman angles and did it more by feel and speed than any scientific working out.
Best bit is you still have control when flying the middle hull!!!----done it a couple of times before the bottle went
15notts on one hull--adrenalin is brown
Kim
Old 02-16-2010, 05:42 PM
Innovator
Rep: 72 Posts: 102
Hi Kim
Thanks for your helpful replies. I'm delighted about the rudder answer as I would much prefer to leave the original A Class rudders intact and simply modify the tiller to suit the Tri.
I'll discuss the beam issue separately, so to avoid cluttering this thread. please contact me directly on alan.loveard@aspac-consulting.com.au so we can exchange pictures etc. Then we can decide what is relevant to add to a neew thread on this forum.
Best regards
Alan
Old 02-23-2010, 05:32 AM
Delane's Avatar
Delane Delane is offline
Rep: 33 Posts: 72
Looks Great
Hi Kim,
That's a great looking tri you've created. And flying the Vaka,,,,wow.
Recycling in boat building shop Sam III Boatbuilding 1 11-27-2009 08:15 AM
Information regarding recycling of wastes generated from small fiber glass boatmaking sivaramakrishna Services & Employment 5 02-03-2009 05:18 PM
Raw intakes, exhaust and other thru hulls on Fiberglass Hulls ChrisN67 Boat Design 7 12-27-2008 01:40 PM
Recycling old Contender molds??? cuonawv Boat Molds 0 02-07-2005 02:40 PM
sailboat recycling rickc Powerboats 10 11-20-2003 12:34 AM
