Before getting too twisted over Sizzors having too light scantlings, weighs too little, or has too little righting moment compared to beach cats that race and win Texel, you've got to consider the very unique goal that Sizzors was designed to achieve: circumnavigating the state of Florida. Things Sizzors needs to do that a typical Texel winning cat cannot do:
1) Traverse very shallow waters for possibly tens of miles (such as Florida Bay when the wind blows from the North, and several rivers).
2) A 40 mile overland portage, and several portages around rapids.
3) Go up and down narrow, shallow rivers with overhanging trees and branches for about a hundred miles.
4) Go up narrow channels and under low bridges to reach checkpoints.
Super low weight, super low resistance at low speeds, very good ergonomics for paddling, easy to drop and raise mast, and adjustable beam are technical enablers to meet those unusual objectives.
The boat and every part of the boat is remarkably light weight -- its almost surreal what Randy has done in his large workshop beneath his house.
As discussed before, the A class mast is a cut down damaged mast he got for almost nothing.
The A class hull used for the main hull (vaka) is dramatically cut down in freeboard, and extended aft, with nicely done structure, all carbon and foam. Its measurably lighter than a typical all carbon A class hull for a 75kg all up A class boat.
The amas are much, much smaller than an A class hull, much more like two surfboards, and weigh perhaps 10 lbs each.
The small diameter round carbon tubes (akas) that "scissor" fore and aft also have lines going through slits in the vaka, and the vertical uprights act structurally as dolphin strikers, so the akas are again dramatically lighter than A class catamaran cross beams while being strong enough for sailing loads. All the damage to such akas have occurred due to non-sailing forces, either while capsized in large breaking seas, or when run over by a powerboat.
Its an amazing boat!
Consider that when using the screecher and full main, the boat has well over one square foot of sail area per pound, crewed and fully loaded for a circumnavigation of Florida.
