| Problem!!! Hi Guys, I have just aquired an old hurrican 4.9 (I think) that needs some repaire, the first job is to remove the stubs of bolt left in after the cross bars were cut off but they are corroded solid into the metal plates they are screwed into, the bolts won't come out of the plate and they plate won't come out of the hulls. The only thing I can think of to do is to drill new holes about half an inch in from the onld ones then to file the old bolts flat, will this effect the strenght of the boat?? ![]() |
| Why not drill out the old bolts. Start with about 1/4" drill and then go up to the size that would be used for a tapping hole. You should only need to drill below the depth of the metal plate and then break the end off from the inside. Making new bolt holes inside the existing ones will reduce rigidity a little because you are getting further away from the side of the hull that provides stiffness to the backing plate. Need to also check that the backing plate actually sits below the proposed holes. For my mind drilling new holes would not be a lot less effort then simply drilling the old bolts out and running a tap though the holes. Rick W |
| We thought about it but drilling out solid 8mm bolts would take some time and the drill bit will have a tendancy to drift into the softer fiberglass. |
I would be putting a lot of effort into removing the old bolt rather than making new holes. Unless you have detail on the design of the connection you could create more problems by relocating the hole. Rick W |
| Problem! | babakshabani | Surface Drives | 14 | 11-13-2007 07:26 AM |
| TV problem | yipster | OnBoard Electronics & Controls | 12 | 11-07-2007 10:32 AM |
| a maxsurf problem | pavel915 | Software | 2 | 12-30-2006 03:16 AM |
| Do I have a problem?? | hiracer | Metal Boat Building | 16 | 08-29-2006 08:05 PM |
| problem | electricvoodoo | Boatbuilding | 7 | 09-09-2005 06:00 AM |
