| proa rigs Proa's seem to sport quite a variety of rigs with c of e varying quite widely in positions..... Harry / Atlantic / EQL seem to be more in line with cats, while pacific seems to a lot more fwd.... Why? Also varies with rig type and the hull weight balances..... ![]() No baseline to judge by and even the "experts" seem to have to experiment lots to find the sweet spot..... ![]() |
| A traditional proa will shunt not tack. The mast leans forward. However, when you shunt the mast leans the other way.
__________________ Gonzo |
Rob |
| For the "traditional" type / pacific - why does it need to be so far fwd/ have a lot of lead? Even with a marconi, the foresail is necessary..... The hull is balanced around the centre - even if altered to bring the bow up - for each direction. While the ballestron/easy seems ideal - it isn't simple or cheap and even on harry's still has a few issue's...... The weight of the ama seems to be at the heart of the issue - ie the harry etc are cat - like enough to have similar rigs... but the light ama of the pac proa seems to be different to all of the above but it doesn't act like a tri or a mono either It also sails as a mono when flying the hull but i guess you set it up for the ama in the water....![]() |
| Hi Alex, with many newer proas the CLR is changed when shunting to get the lead as the daggerboard/rudders are raised and lowered so the rig doesn't need to shift forward. Remember the traditional types were sailed with movable ballast (lots of crew). for stability making a light ama appropriate. There are plenty of people working with crab claw rigs you can find on the internet, properly set up they go to windward well and are more effient on a area basis than other rigs. Shunting isn't easier however... |
| The mast pivots and tilts forward when you shunt.
| While i am interested in the crabclaw - it is isn't ideal for shunting..... shorthanded or on a smaller boat. I like the proa concept but rig and rudders remain an issue.... i am also trying to get away with not using daggerboards This is probably the main problem.......![]() What works on small models doesn't necessarilly translate into reality ![]() |
My 7.5 sails perfectly well with just a mainsail (has no headsail), as do the easy rigged proas. Shunting can be a bit more difficult, but easy enough if you are aware of what you are doing. Quote:
rob |
| Thanks Rob. Was thinking of a cross-over rudder/paddle - along the lines of Wharrams ethnic range..... either/or. No rocker or slab sides I want the hulls to do enough that i wont need boards.. High cp & flat bottomed - similar to your concept Rob. As no need to tack - should work fine![]() The issues were read from older yahoo forums - got you to answer tho ![]() Crab claw - yes i know most (you Rob) dont like them - but as a DIY rig for an ameteur like me, it will be an ok place to start.... if i hate it i can always change it later. Still playing/testing/learning - it never seems to stop ![]() |
| From the internet pictures I have seen, I like the simplicity of a schooner rig with two high aspect identical mainsails, that just swing round the back of the mast, sorry no idea what they had under the water, just remembered it looked very nice. |
| Probably CLC's Pacific Proa (Mbuli). Go here: http://www.clcboats.com/shop/boats/w...ser-plans.html I think the one with the Flettner rotary sail is boundlessly amusing. |
| I think the Flettner Rotor is a very creative idea! I'd like to know more about THAT one! |
| The principle used by the Flettner rotary sail is the Magnus Effect. Sadly, it is not as efficient as using the same motor to turn a propeller to push water. Wikipedia has a very good article here: http://en.wikipedia.org/wiki/Magnus_effect |
__________________ Only shared knowledge can grow. |
| Fletner is being used by those guys combating global warming with searunners. Marples is involved, so I have to wonder how hopeless the rig is... on a small boat did they pedal power the rig? Norwood was a great proponent of the pyramid rig, can't recall why, any ideas on that? I would be a little cautious Alex about any testbed project of any size above a skiff. I am not convinced a let's chase ideas approach is as good as a solid plan that is executed, even if the plan is not perfect. Michael Schacht's proa comes to mind as a sincere project that never got working, and the other extreme are Rob's boats that however successful are never finsihed and sailing, which is just fine if the enquiry is the main thing, but not if using them is any part of it. It is pretty easy to see ten productive yeears slide by on boatbuilding projects. |
| Aftmast rigs??? | jdardozzi | Sailboats | 492 | 03-22-2012 03:11 PM |
| Gaff rigs | Manie B | Boat Design | 40 | 06-23-2008 04:08 PM |
| Sail Rigs | john.G | Sailboats | 24 | 10-23-2006 09:37 AM |
| junk rigs | geoffr | Sailboats | 20 | 05-01-2006 07:10 PM |
| Reactive rigs | yokebutt | Sailboats | 1 | 04-07-2005 04:46 AM |
