Old 10-06-2009, 03:33 AM
tallshipskip tallshipskip is offline
Captain caveman
Rep: 10 Posts: 4
Power Tri... thoughts?
Being brave and posting a design I have done of my 46' power tri... I have built a 2.3m scale model of her and performs quite well. Construction of the big one is due to start next month. The boat, both model and full size are to be built out of polycore.
Just posting a rendering I have done as well as a pic of the model on its first test... and yes its actually moving in the pic.
I am curious to see/hear any feedback or comments on this...
Old 10-06-2009, 04:25 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2356 Posts: 2,476
From an aesthetic point of view, I think you could flare the hull at the bow above the chine a bit more, to gain some useful space on the deck and to avoid that (imho ugly) concave sheer visible in the first pic.
Can't say more about hull configuration from these photos and without knowing boat's dimensions and your design goals. How did you determine the length of the amas and their position relative to the main hull?
Old 10-06-2009, 05:03 AM
boat fan's Avatar
boat fan boat fan is offline
Rep: 357 Posts: 679
Looking forward to this tallshipskip.
Very interested in a build using polycore.
I understand it is quite economical.
Pictures would be nice.
Old 10-06-2009, 07:18 AM
Captain caveman
Rep: 10 Posts: 4
Thanks..
My main experience has risen from being a crew member on Earthrace for some time during her Australian Tour.
This design is aimed at maximizing living space while maintaining relatively good performance/economy.
Thank you Daiquiri for your comments.
Boat fan, yes Polycore is really quite economical to build with, for the full size boat I will be ordering pre-glassed panels at upto 6x2.4m. It is a incredibly easy product to work with, very user friendly with great product support from the guys at polycore.
www.polycore.com.au
Old 10-06-2009, 05:36 PM
boat fan's Avatar
Rep: 357 Posts: 679
Is there an easy way to convert a build from an original plywood design to Polycore without re-engineering the whole boat ?
Old 10-06-2009, 06:48 PM
Captain caveman
Rep: 10 Posts: 4
Polycore will easily fit any ply design, as it is available in 8x4 sheets the same as ply. It will also speed up the process as it's much easier and more workable. The tri design I have done above is completely based around 'flat panel'
Old 10-06-2009, 07:27 PM
boat fan's Avatar
Rep: 357 Posts: 679
Thanks Tallshipskip.
Are there any charts that compare strength / stiffness of polycore with plywood ?
For example , if you have 1/2 inch ( or 12mm ) plywood , how to select the appropriate Polycore panel ?
Do you build stitch and glue style ?...Sorry , too many questions....
Old 10-06-2009, 08:10 PM
Captain caveman
Rep: 10 Posts: 4
[quote=boat fan;304784]Thanks Tallshipskip.
G'day Mate, feel free to give me a call on 0433 608 158 and I'll give you as much info as I can. I'll track down some info for you too.
G
Easy 37, any thoughts? ThisnThat Multihulls 3 11-14-2008 07:05 PM
Wanting to build a Power 20'-22' TRI ncstriper Multihulls 0 03-04-2008 08:07 AM
Another Human Power Thread - Monohull, Cat or Tri or something odder? alexlebrit Boat Design 0 07-14-2007 04:11 PM
Any Thoughts ncarter Motorsailers 6 11-22-2006 06:09 AM
some thoughts... rotorhead Boat Design 0 08-17-2006 07:09 AM
