| Is power catamaran capsize safer than sail catamaran? Is power catamaran capsize safer than sail catamaran? I believe yes, but wish ask more experienced here... |
| They say yes, power is less likely to capsize. Why? First of all, you can't have a wind induced capsize from too much sail up in windy conditions. This is the most common reason for catamaran capsize. Second, you have a lot of weight down low in the form of engines and fuel. In addition to the dimensional stability of the two widely spaced hulls, this gives you even a bit better of a righting moment from weight distribution as well. A sailing cat, in most instances, will have a center of mass that is a bit higher up than a power cat.
| And if power catamaran capsize, he stay capsized too? Or hard sea can alone latter back him in normal position maybe? |
| If any catamaran capsizes it's a bad day, power or sail. Neither recover very well and no they will not "self recover" without the assistance of a big crane or hurricane whipped seas. |
| It depends on the design. The method of propulsion alone is not enough to determine an answer.
__________________ Gonzo |
| What Gonzo says gatta be true- I have seen some power cats with so much freeboard and house area you might as well have a sail you can't take down. |
| yes, I see... yes, traditional designed power cats it seems lot more safe hm, but what you say to this non-traditional design? http://www.planetsolar.org/wp-conten...isu_home_1.jpg I believe this cat is not for any bad weather... what you guys say? |
| There isn't a tradition on power catamarans yet, they are new-comers.
| Ask anyone from Kansas; barn doors do fly. So this example is probably not the best way to survive heavy weather. I suspect only an enclosed, self propelled life boat, painted international orange is the best bet. Add another consideration to your powercat question; beam. There are examples of production powercats with beams narrow enough to fit in a large slip. They may be two or more stories high ( but none to my knowledge have elevators or escalators YET.) Others may not have enough power to keep the bows into the wind in a stiff blow. The last consideration is training. I'm sure that anyone who can carry a 4 x 8 foot piece of 3/4" plywood on his head across a frozen lake in a blizzard could handle that PlanetSolar very-nearly-a-trimaran in a blow. Naval architects use a related term, Metacenter, to talk about this problem. It's not hard to come up with. Gonzo: I'm looking at a powercat built in 1962. Isn't 50 old enough? |
| building a sail/row catamaran | sail102 | Multihulls | 15 | 11-30-2011 06:34 PM |
| e-motor sail-catamaran | anton | Propulsion | 3 | 11-22-2010 03:18 AM |
| Catamaran hull difference sail / power | Fanie | Multihulls | 23 | 10-25-2007 08:16 AM |
| Daycharter Sail Catamaran Plans? | caribmon | Boat Design | 2 | 05-06-2005 02:57 PM |
| Power / Sail catamaran | vectorges | Boat Design | 2 | 04-22-2004 02:20 PM |
