Old 02-26-2009, 11:54 PM
Ernie Travers Ernie Travers is offline
Rep: 30 Posts: 10
Hello 2farnorth,
I did not read your Specifications before I answered.
I am an older guy with a good marine education and an amazing amount of experience.
I am not flash on the computer as my hands on skills are in more demand.
Running a boatbuilding operation, I have had to do everything in the factory at some time from being a managing director, all office work and all building trades work.
I had to design new hulls when needed and the result was spectacular. It took me by surprise.
None of us know everything and we all know something. Cooperation will get us everywhere.
Good luck with your project. I would like to follow it with interest.
Old 02-27-2009, 12:22 AM
masalai masalai is online now
masalai
Rep: 1689 Posts: 7,510
To power you need a long and skinny hullform say 40ft loa and 2 ft 3 ins max beam wl on a similar draft, chines below the wl will give a displacement MAX in the vicinity of 5 tonnes (about 11000 lbs) and Rick Willoughby may help you to optimise it for efficiency....
Remember do not EVER overload the design as cats are critical on weight issues... google and download a copy of freeship / delftship free of the russian version (stable) from here http://freeship-plus.pisem.su/indexEN.html - then click on <support> then <downloads> and choose one that is beyond "test" (ver 2.95) and enjoy the learning experience...
Try to be helpful...
Remember that there are at least two sides for every story...
Old 02-27-2009, 08:31 AM
2farnorth 2farnorth is offline
Rep: 10 Posts: 38
Ernie, I would be interested to see the hulls you designed. If you all want to see what I am shooting for, compu craft down in Australia has several designs that I like, check out the C-C 38/40 power cat at this web site http://www.ccplans.com/index.cfm?Do=View.Page&PageID=41 , but I do not have $8500 laying around, I figure if I can get some hull plans for under $1000 I could do some modifying to suit my needs.
Old 02-27-2009, 08:39 AM
Rep: 10 Posts: 38
Masalai, Thanks for the reply. I like to here from you guys down under as it seems catamarans are the norm down there. I am not a designer so I guess I am just looking for the hull design that you are talking about. 40' LOA and narrow at the water line.
Old 02-27-2009, 03:42 PM
masalai
Or else go for the one I am building (boats are a compromise of wants and needs) - - click the link at the bottom of my post "My little piece" in hyperlink blue and underlined.... there is a changed underwater line powercat range as well to look at.... Pay 2 or three people to help you build and you are away for about Au$300,000.00 if you build in Aussy
Old 05-08-2009, 04:57 AM
Rep: 30 Posts: 10
Helo 2farnorth,
I didn't read your thread properley before I answered and haveonly just found the forum again.
Old 05-08-2009, 04:32 PM
masalai
2farnorth, My initial kit cost about AU$60,000 + Au$6000 for build plans & rights for one boat - the difficulty is in the z-press which is water heated to set the 'techniglue' and on a 30deg celsius day ambient can do a join every 20 minutes - 8ft side of an 8' x 4' routed panel - 4 kits will fit inside a 40' standard container, and all the panels on a pallet weigh 1100kg and the other pallet has all the chemicals and rolls of glass etc. there is also a set of build frames that should last the 4 builds if used carefully. you would need a 'true' leveled concrete floored shed about 30ft x 50ft for comfort and a sea-container as your tools lockup along with corded powertools of a jigsaw with metal cutting blades (glass destroys the others too quickly) a 4" anglegrinder with sanding disks, a belt sander (small and not expensive), an aircompressor for powering the "helicopter" sanding tool for fairing the large flat surfaces (all must be bogged and sanded back after removing the peelply and painted inside with at least "flowcoat" and externally with 2 part marine paint and specialist underwater coat... and for the curves 4-6 handheld small sanders (find extra volunteers to help in this "painful" but necessary task) oh and a cheap electric drill to mix the epoxy and stuff and a pair of cheap electric screwdrivers - I am sure I have missed several things, but is is fun and visually rewarding... Including tools and sundry other costs and help - AU$75K so far...
There is a powercat version of this boat - slightly skinnier and different underwater lines - in-keeping with current displacement high speed power design here in Aussy
Then comes the hard fiddley part of fitout and rigging etc....
house bout with cat hulls jawshunter Multihulls 12 12-08-2007 06:10 PM
Power Cat Hulls bearwen Boat Design 2 11-30-2005 01:20 PM
Sail power and horse power? kjell Motorsailers 12 09-03-2005 03:20 AM
Thickness of aluminum cat hulls JonathanCole Materials 3 08-24-2005 05:03 PM
Thickness of aluminum cat hulls? JonathanCole Metal Boat Building 4 08-18-2005 10:17 PM
