Old 02-07-2010, 09:07 PM
nwguy's Avatar
nwguy nwguy is offline
Plywood or balsa core?
I'm building a 16 foot trimaran to replace this boat:
http://www.outsideconnection.com/gallant/trimaran/
Will keep the rig, but am building new amas of foam/glass construction and a new center hull. I bought 29 end grain balsa panels from a guy that are 7/8" thick, and I'm considering using these for the hull construction. My other choice is okoume plywood either stitched and glued or traditionally built. Am leaning towards a hull shape like an international Moth 14, but with 2' high side walls for a dry ride. Obviously this would be a day sailer that lives out of the water, and I'm aware of balsa's tendency to rot when wet. What I don't know is the following:
1. How thick is balsa normally when used for hull walls and bottoms? Is 7/8" too thick?
2. Would it end up being heavy due to the amount of epoxy resin that would be absorbed into the end grain balsa? And heavier due to glass needing to be laminated on to the inside too, whereas with plywood it wouldn't be mandatory everywhere?
3. Must you vacuum bag when laminating fiberglass on balsa, or can you prime with resin, lay the glass on and wet out with a roller like with stitch and glue?
Thanks, nice to be here (my first post).
Old 02-07-2010, 10:36 PM
jmolan jmolan is offline
Rep: 65 Posts: 65
http://www.jamestowndistributors.com...+-+West+System
There is a good page on comparing different building material, cost, weight.
Good luck!
Jack
__ http://tiny.cc/lvk1Q
http://tiny.cc/V5Nyz
Glassed balsa core frank smith Materials 5 10-23-2009 01:11 PM
balsa core Mihajlo Fiberglass and Composite Boat Building 1 10-22-2006 10:18 AM
Balsa core vs. foam core James Maldonado Fiberglass and Composite Boat Building 23 01-21-2006 11:12 PM
Where can I buy some Balsa Core for my J 29 Cliff Ruckstuhl Materials 1 07-18-2005 07:45 AM
Balsa Core? Guest Materials 14 10-27-2004 06:17 AM
