Old 05-10-2008, 08:08 AM
neelie neelie is offline
Rep: 10 Posts: 7
Overpowered engines on a Sailing Cat - consequences?
I am looking at a 47 ft Cat, Design Displacement of 26,000 lbs, it has 2 x 100 HP engines installed... yes, a hundred HP per side.
The weight difference from the "usual" 40HP would be nominal, the engines are located in a more central position as they are not sail drives, so I'm guessing that trim may not be a big factor
It is a sailboat and I am wondering why on earth they chose to overpower it.
Apart from guzzling fuel at an alarming rate, are there any other negative structural or seaworthy consequences?
Last edited by neelie : 05-10-2008 at 08:22 AM. Reason: finger trouble on first attempt
Old 05-10-2008, 08:53 AM
nero nero is offline
Rep: 112 Posts: 624
heat produced by the engines will be greater.
Fuel consumption could be less. On big trucks the owners were running bigger engines at lower rpms. They got better milage than heavily taxing a smaller engine.
Old 05-10-2008, 12:59 PM
Fanie's Avatar
Fanie Fanie is online now
Fanie
Rep: 1930 Posts: 4,195
Hello Neely,
There is nothing wrong with having big motors on a cat, and a 100 is not that big ! 100hp motors are the size on the verge of becomming fuel hungry, so if you take it easy and not open kettels all the way you could travel some distance without paying an arm and a leg for fuel.
Some advantages are, you can turn the boat against a strong wind, something you may not be able to do with a couple of 40hp.
You can use it as a motorised boat and get where you want to go without having to rely on sails, and at speed.
I plan something similar, but smaller - you can choose what it is, a power boat or a sailor.
The sailing option can make it more economic if you're not in a big hurry.
Sounds like a very nice rig though. I don't think the guy lost his marbles, I'd prefer those 100'ds to 40's any time, so if you're putting 40's on send those 100'ds to me ok
Regards
Fanie
Water ! Just gimme water !
Looking for aluminum sailing cat plans cleblanc Multihulls 9 10-27-2006 09:11 PM
Planing hulls for sailing cat Peter Brown Multihulls 14 05-30-2006 02:09 PM
Free 25' sailing cat building molds... Billy Bones Wooden Boat Building and Restoration 0 05-24-2006 12:05 PM
Hydrofoil Supported Sailing Cat Hatchman Multihulls 9 01-25-2005 09:25 AM
Marine Engines for Sailing Matthew Boat Design 9 07-08-2002 01:07 PM
