  #31
Old 09-07-2009, 04:36 PM
erikhaha erikhaha is offline
Rep: 66 Posts: 36
Hey BWD good to see you have made some progress since last time. So far she looks real nice.
I have also made some progress on mine but not as much as I'd like to have. Being married and having a full time job cuts into my building time. Damn work.
Here are a few pictures of what I have done so far. Just today I finished the bulkhead under the forward beam, but now I have to epoxy it into place and fillet all the seams that it makes with the hull. Before I was trying to make a folding system, but I have since abandoned that idea for a simpler single 4” diameter x 1/8” thick Aluminum tube section fore & aft.
I also used Dierking’s book to make the Vaka, which is a modified Ulua. Since then I have designed most everything else, or taken from examples I have seen. I just started making one of the 2 outriggers. It will be 16ft long 16”x16”x16” triangle with a tapered front section. I am using ¼” marine plywood, stitch & glue method.
Well, I have to go and work a little more on her before it gets dark.
Outrigger canoe plan....-beam-bulk2.jpg  Outrigger canoe plan....-beam-bulkhead.jpg
  #32
Old 09-09-2009, 12:46 PM
dstgean dstgean is offline
Rep: 68 Posts: 136
[QUOTE You can check it out at the link for 2009 at www.t200.com
Dan[/quote]
That should read www.texas200.com not the troop 200 of the Boy scouts.
Dan
Malibu Outrigger Plans fhrussell Boatbuilding 9 07-04-2008 04:05 PM
4 man outrigger build jc9_0 Fiberglass and Composite Boat Building 0 04-06-2006 03:44 PM
Malibu Outrigger Burr1 Open Discussion: All Things Boats & Boating 1 10-02-2005 09:41 PM
Outrigger balance jdoorly Boat Design 8 10-19-2004 08:45 PM
Outrigger canoe sailer Frogman111 Sailboats 3 06-07-2004 04:29 PM
