| outrigger canoe with only one iato I was wondering if it's possible to get rid of the front iato on an outrigger canoe (paddled only, no sail activity therefore less stress on the structure). my first intuition : A stiffer rear iato, with lateral reinforcement on the ama side. Could be lashed the traditional way on the hull side (perpendicular to the hull axis) and lashed on the ama side along its axis. The said iato should roughly look like a T, with some kind of triangulation where both axis are joining. Did someone try anything similar ? Could we discuss material resistance forecast ? |
| Here are some pictures of traditional and racing outrigger canoes. Only the forward iako is load bearing. The aft iako apperars to act as a spring, damping and limiting movement. Perhaps if you were to make the forward iako a torsion bar (fleeting visions of Volkswagen Beetle front suspensions) you could delete the aft. |
| By the way, do visit Teva Sylvain's website: http://www.pacific-promotion.com.fr/TSylvainEN.html It can make a dreary winter day a little brighter. |
| Thanks Darthcluin. Actually, the idea is the other way round, in order to clear the front for paddling purpose. The front iato shown here is quite interesting, its design could fit as a rear one, alone, and centered on the ama (just like it seems to be on the pictures) what about strength issues ? |
| Search for Glen tieman--he uses one that's 25# or so as a tender for his Wharram cat. Dan |
| Thank you sooo much dan, this is just what I had in mind ! http://www.latitude38.com/lectronic/...11-09&dayid=30 you may have to scroll down a bit to see the said outrigger, and the man in it. Inspiring ! Do you know any way to get in touch with glenn ? |
| Here's some of his updates that he sends to the Wharram people, but there's nothing new since May. http://wharram.eu//live//index.php?t...80416175514782 |
| Building an Outrigger Canoe | spenny | Boat Design | 7 | 12-06-2010 12:41 PM |
| kayak/canoe outrigger issue | fabrice | Multihulls | 8 | 04-02-2010 02:42 PM |
| Outrigger canoe plan.... | BWD | Multihulls | 31 | 09-09-2009 12:46 PM |
| Powered outrigger canoe | Shinchan | Boat Design | 3 | 02-12-2007 04:44 AM |
| Outrigger canoe sailer | Frogman111 | Sailboats | 3 | 06-07-2004 04:29 PM |
