Old 06-07-2009, 01:29 PM
kelldog kelldog is offline
Rep: 15 Posts: 31
Outboard Motor Well
Outboard Motor Well
Greetings to all;
New member here....
I am considering cutting out a well in my Cross trimaran for my outboard motor. There is a spot where the framework has been built in to do this but was not finished. I have a 5hp 4 stroke that I use ( I need/want a 9.9hp) and with the outboard bracket I use I still have an issue with cavitation in choppy water. Drives me nuts!!!
I would have to rig something that would allow me to raise the motor up when not in use. I don't think I have enough clearance to be able to get the prop completely out of the water but that might be ok.
Any ideas or thoughts on this? My Cross is 28/30 ft. The well is in front of the rudder and alittle to the starboard side...not centered.
Thanks your input
Kelly
S/V Mystic
Long Beach, Ca
Old 06-07-2009, 11:10 PM
peterAustralia peterAustralia is offline
Rep: 170 Posts: 162
I have a well in my small multi.
I found that I had problems is a chop in that the motor would make funny sounds when a wave passed. I worked out that the exhaust was too deep in that water and creating back pressure. So it was not the well itself but insufficient height of the well.
You need a plate of some sort that goes back when the motor is removed to retain a smooth flow. To get the motor out easily, I suppose some sort of rotating mechanism. so that the motor fits onto a block (4 x 2 timber) that sits on the lip of your well, but is not physically attached to the well. This way the whole thing could be lifted out.
The trouble with this is that you would need space forward for rotating arms for the mechanism.
A vertical sliding mechanism might work too, but it would need to be braced securely to the well before the motor is used.
You do not have enough length in your well to have the motor just kickup normally...
outboard motor well placement Delaney Boat Design 4 05-24-2009 10:15 AM
Outboard Motor Out-Mounts or Outboard Bracket Installation Recommendations Guest Powerboats 9 08-28-2007 04:54 AM
Choosing a outboard motor blared Powerboats 14 07-08-2007 01:06 PM
outboard motor well J Ralph Boatbuilding 10 11-05-2004 07:25 PM
Outboard Motor Mounting Height Guest Powerboats 4 10-31-2003 04:55 PM
