Old 07-09-2006, 03:39 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Orange 2 takes new Atlantic record
Word on the street has it that the French supermaxi cat, Orange II, set a new trans-Atlantic record of 4 days, 8 hours, 23 minutes 54 seconds when it passed Lizard Point on Friday. And this with only 12 crew on two watches, and after losing a rudder in the middle of the ocean.
http://www.gizmag.com/go/5833/
http://www.sail-world.com/news.cfm?N...estTimeOut=180
http://www.ybw.com/auto/newsdesk/200...649ywnews.html
Any thoughts?
Old 07-09-2006, 05:33 PM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,269
averaging 27 knt 4 days 8 hrs 23 minutes not metioning the seconds, minus 8 hrs for the rudder accident,
and more maxi's coming up, sounds good, proficiat
Old 07-10-2006, 12:08 PM
rayaldridge's Avatar
Rep: 292 Posts: 572
Why cats?
So why have the record-breakers been cats, lately? Isn't it generally accepted that trimarans are faster over ocean courses, because they do better in light air? Or is it that these record-setting crossings are planned so that there is as little light air as possible, and that the big cats are better able to handle the heavy air?
Ray
Old 07-29-2006, 11:12 AM
Seafarer24 Seafarer24 is offline
Sunset Chaser
Rep: 22 Posts: 203
Ray- think about it for a moment. If you don't have the wind to go 40 knots, you're not going to beat the record. If you've got that much wind, you're better off in a catamaran. If you've got to cross the Atlantic in 4 days or less, you can time it to play the weather.
Old 07-30-2006, 09:12 PM
frosh's Avatar
frosh frosh is offline
Rep: 44 Posts: 621
Why Cats?
Even though there are wealthy sponsors in place for the super maxi high tech multihulls the costs are astronomical compared to regular boats. Also considering that they are one offs, and the hulls and beams at least require molds to be built, a catamaran with one hull shape and a simpler beam structure must be considerably cheaper than constructing plugs, molds and hulls for two different shapes. Also the crossbeams are greater in number on a tri, and each would require an individual mold. I would also guess that construction time would be longer also.
Maybe the sponsors do not really care about the final cost, but it could be a factor.
Hydroptere takes new direction Chris Ostlind Sailboats 2 05-30-2006 04:27 PM
How long takes engineer study in your country =D= Education 22 04-06-2006 10:39 AM
Atlantic crossing in a traditional boat Vega Sailboats 14 03-18-2006 03:03 PM
signal orange paint for rudders and keels boogie Materials 2 03-18-2006 07:25 AM
Hankinson 23' Atlantic Skiff ajse Fiberglass and Composite Boat Building 0 05-25-2004 06:17 PM
