| Onboard Video - Hydrofoil Trimaran Broomstick Sailing my foiler Broomstick had to take a back seat to other activities in 2011, so there's very little progress to report for the year. However, my 90-year old mother in Florida sent me a GoPro Hero for a birthday gift last spring. Just for fun, I've put together a short video of clips from 3 outings last summer. http://vimeo.com/34164014 Comments are welcomed. Just don't be too hard on me; this is my first attempt at any real video editing (other than just extracting pieces). Doug Halsey |
| Broomstick Doug, for me the video is stopping every few seconds and stopped for good about a third of the way thru. The earlier test version worked straight thru ok. A question: how much wind to get on foils? How high can you point? PS- the speed shots are out of sight! Video stopped less third time-don't know if its my machine or what......
| She's a beauty Doug, great video. I noticed some runs had an ama on the ends of the beams and not on other runs, what is the reason for this? different conditions? Crashes were interesting and the end of the video was great! ![]() Thanks ps the video worked fine for me |
| Great video and congratulations in creating something which looks great fun. ![]() Be great to see some more shots of the craft and hear more about its design and construction. |
| Problems Viewing the Video Quote:
Here's the suggestions from Vimeo Support : Quote:
Doug Halsey |
| Video ran fine for me without interuption, I've found a Word document you wrote Doug on foils.org which has provided a lot more information. ![]() |
Doug, when I used your link to go to the "old" video it didn't require the password and looked like the new video-until it started running: no music and no stops whatsoever! The boat looks so good! PS- I haven't had a problem on vimeo before......everybody else seems to be ok-don't get it-as far as I know I have up to date stuff. ---- A bit more on Broomstick: Taking Off the Training Wheels (Sailing a Hydrofoil Trimaran Without the Amas)
| Doug, This was great, congratulations on getting up on foils. I know it is more common now but lots of people have had lots of trouble. You have obviously discovered the problem with pure foils on the cross beam, little ability to get started. The amas were a good idea, I would like to see video of you starting from a dead stop. My guess is that a bigger ama would make the crashes and the start much easier. Do you have pictures from the side? What rig are you using? Are you willing to show the foils? I don't want to steal any ideas, but it is interesting to see what is working. How much does the boat weigh? Great Video. Thanks Marc |
| More Information on Broomstick For many viewers, this video is just a general introduction to the boat. I'm hoping to eventually put together some more informative videos to explain various aspects of designing & sailing surface-piercing foilers. In the meantime, more information about Broomstick can be found at : 1. http://www.foils.org/gallery/071111%20Broomstick_4.htm 3.Broomstick Breaks 25 Knots! 4. Taking Off the Training Wheels (Sailing a Hydrofoil Trimaran Without the Amas)I'm also glad to answer questions in this thread, but I only have a limited amount of time that I afford to spend on the computer these days, so you might not get quick answers. Thank you (everyboby) for your comments. Doug Halsey |
| Doug(and anyone interested in more Broomstick info), I've moved the 2010 Foiler Design material(still there) to the new thread in the "Hydrodynamics and Aerodynamics" forum under Sailing Foiler Design. Sailing Foiler Design: Foil Assist and Full Flying
| Doug, Looks like I should have researched further before making useless suggestions (putting on amas). |
| Version of Video With No Music Quote:
http://vimeo.com/32782915 Doug Halsey |
| looks like a ton of fun
__________________ I am skeptical of the deniers diatribe |
| Sailing With or Without the Amas A couple of people have asked about this. Quote:
In addition to the obvious advantages to sailing without amas (less weight & windage), I've found 2 more : 1. Less drag due to heeling in semi-foiling mode. This requires some explanation. Being a fairly "conventional" surface-piercing foiler, Broomstick doesn't have large enough foils to fly much of the time, so it's performance when the main hull is at least partially in the water is of major concern to me. Going to windward, it's takeoff speed of 12 knots or so just isn't going to happen until the wind is up in the mid-teens. But the foils still are effective for combatting heeling. When the boat heels enough for the leeward ama to just touch the water, I can instantly feel the extra drag & sometimes it feels like the ama actually grabs the water & makes it heel more. (What I think is actually happening is that the extra drag slows the boat, causing less lift on the foil & hence less righting moment.) Without the amas, it sails to windward much more smoothly & is far easier to sail.2. Easier to right when turtled. With the amas, it's impossible for me to right it. I have to remove one before my weight is enough to sink one side. Without the amas, the boat is more likely to turtle if it capsizes, but it's no real problem if it does.Because my amas are attached to the crossbeams with loops of bungee cord, they only take a minute or so to attach or detach. (Here, I'm referring to the 7' amas that I use when I'm sailing Broomstick as a foiler. I also have a set of 11' amas & a daggerboard that I can use for sailing as a conventional trimaran without the foils.) On a typical day, I usually attach the amas for rigging at anchor, get warmed up a bit by sailing with them attached for a while, then remove them for some more "serious" sailing. If the wind is particularly fluky, or I'm feeling more like taking it easy or writing notes, etc, sometimes I'll just leave the amas attached. But, as I said above, I very much prefer sailing without them. Doug Halsey |
| Great stuff, Doug. Like I said before, you've got courage, a better man than I am, Gunga Din. The crashes reminded me of a certain previous boat of mine, now defunct ... but being sort of resurrected by another crazy (Mickey Knuckey) on Waiheke Island; he motored there with the broken beam and ama across the boat, a proa; quite an ordeal because it blew up to 25 knots and the hatch was lost, he baled with a paper coffee cup ... which failed. Here's Sid - working on getting the full wing bearing correct at the moment. |
| Taking Off the Training Wheels (Sailing a Hydrofoil Trimaran Without the Amas) | Doug Halsey | Multihulls | 38 | 04-27-2010 07:26 AM |
| Onboard PC | glenn.225 | OnBoard Electronics & Controls | 42 | 03-26-2010 04:08 AM |
| Broomstick Breaks 25 Knots! | Doug Halsey | Multihulls | 2 | 05-15-2008 03:29 PM |
| Discussion- Multipurpose Onboard Computers: Monitoring and Control of Onboard Systems | TerryKing | OnBoard Electronics & Controls | 4 | 11-07-2007 10:16 PM |
| Onboard Computers | TerryKing | Wiki | 38 | 05-26-2007 05:39 AM |
