| Newcomer on daggerboards Hi! I have an old cruiser-cat with a centerboard between the hulls. The upwind performance is ... bad. I intend to build a new board and have been playing around with the Profili 2 software based on the Xfoil simulator to learn more. I have a few questions that I haven't found answers to anywhere else and I hope someone would like to help. 1. Xfoil computes a Cd/drag coefficient somewhere in the range 0.005-0.03 for normal angles of attack. What reference area is used to calculate the actual dragforce for the Cd reported by Xfoil? 2. NACA 00XX profiles seem to outperform almost any other profile in the database in the Reynoldsrange I am interested in. Is this due to a favorable coincidence between Xfoil analysis algorithms and the research done by NACA on profiles or could I expect the NACA 00XX to be the strongest candiate on sea? 3. Some of the designs I've seen around Stockholm use daggerbord profiles similar to Eppler 521 or symmetrical NACA 64XX that are slightly concave in the 75-85% part of the foil. But these profiles have few or no advantages compared to NACA 00XX according to Xfoil. Even the assymetrical boards on the 60foot Tri's I have seen have a concave area. What am I missing? Does the noncompressibility of water make Xfoil a bad choice of simulator for my application? 4. A question on planform too ... i have seen somwhere that the reduction on Cl/lift coefficient due to wingtip effects can be computed with the ratio AR/(AR+2) for an aircraft wing. Will this apply for a centerboard as well? I think the reduction should be less since there is only one wingtip. I addition the AR for the daggerboard is computed on only half an aircraft wing. What would be an appropriate Cl-reduction-factor for a centerboard? If any other info needed ... please ask. BR /T |
| I think that naca 0010 to 0015 give the best overall performance. Most other profiles try to optimize for certain conditions that are seldom met i real sailing. Does your centerboard hang free in the water? You double the effective aspect ratio if its under a hull. Some useful stuff here, from David Vacanti, www.proboat-digital.com/proboat/200506/ look at his article starting at page 76 (use the menu "Content") This may also be interesting for you :-) http://www.mboats.no/Hardware/hardware.htm High quality naca profiles produced in extruded aluminium in Sweden... |
| Nice article! Thanks for the useful advice, most of my thought are clarified. Quote:
Seems as if Q1 and part of Q4 are still looking for answers although the article clarified a lot. Anyone? BR /T |
| Think I have to tell, it's my products in a way, I don't make them, but I sell them (the alu profiles). :-) |
You may want to decrease the exponent used to predict laminar to turbulent transition (ncrit). The default value of 9 is good for air, but something more like 3 seems to give results that match experimental data better for water. Quote:
XFOIL is very good for incompressible flow. Except for maximum lift, its predictions are probably about as accurate as much of the published experimental data, especially the early NACA results. A cambered section like is used for a daggerboard can make better use of a laminar flow section because the camber allows the drag bucket to be positioned over the operating range of lift coefficients. Probably the most important thing you can do to reduce the drag of your board is to make it deep. Quote:
This spreadsheet will allow you to calculate the effect of planform shape and size, and assumption about the surface effects. The hull can be represented as part of the planform, possibly with a reduced lift curve slope and/or lateral area if you want to take credit for its end-plate effect.
| Deeply Thankfull! This really helps, Thank you, Tom! It is really wonderful to be able to get in touch with the best knowledge available in this matter, beeing an ordinary world citizen. Thanks again, Tom. This spreadsheet will help me to take the next step in understanding how planform interacts with the basic lift/drag characteristics from 2D analysis. Now I "only" have to sharpen my english and dig in to understanding what the figures really mean. This is probably way beyond the scope of my application for today (cb to an old 23-foot cruise ply-cat) but nevertheless fun and engouraging to further design challenges.All the best! /T |
| Newcomer to the Industry | JP2 | Services & Employment | 0 | 10-03-2004 04:35 PM |
| Assymetrical daggerboards | Guest | Sailboats | 12 | 06-11-2004 07:57 AM |
| Assymetric daggerboards | danielro | Sailboats | 10 | 12-21-2003 03:19 PM |
| Daggerboards | jefe | Sailboats | 2 | 09-25-2003 04:39 PM |
| Boat Design - Newcomer | Doug | Open Discussion: All Things Boats & Boating | 0 | 08-31-2002 10:25 AM |
