| New steel outrigger 80 foot long MIG welded steel hull and folding outrigger . Outrigger is small , ballasted , air pumped only enough to sink and bouy to keep hull planing . Outrigger can be folded under the hull . Everything is steel , aluminum is weaker for the money . Masts are forged tube , thin wall , since its forged , the mast can be welded up / built up . sails are all luff wire , free , not grooved to any mast . Aux : 4 Honda B18b turbo , variable cam timing nix's waste gate . Im a lonely Ham radio operator , get a permit and chat with me on 14.313 mhz or ECHO link or STAR or whatever the latest is Give me a day or so to build an antenna ( im an antenna expert ) . KC7CC Tucson AZ . |
| Thank You Mr Wynand , STEEL is the fastest , safest and it can be forged to do tasks , no one today DARES , such as masts . It gets better ... Alum masts are extruded , you cant do EXTRUSION at home . But Steel masts can be inexpensively forged in your backyard . A hydraulic concrete breaker is far to much force , thus anything small but not including a $150 Electric Dem' Hammer . Next you need to heat locally to any heat , that reduces the work to reform the grains in the steel til they are flat like corn flakes . Four times the strength of CRS sheet and plate . MIG welding does not interfere , you can MIG a complicated structure and then get on with the FORGING . I have airplane propellors on the drawing board , Forged then brazed . Brazing is very strongs for its weight . It takes shock loads well , thus airplane propellors .... Heat dont matter , unless its red hot under the palm tree you are using for shade , in the Bahamas . Yet its a waste of heating torch or oven to not heat the steel to at least dull red , as seen looking into the un lit oven ... |
| fixing one foot diameter hole in Ferro Hull 32 foot | luckyscott | Materials | 17 | 01-21-2011 01:45 PM |
| 70+ long ally or steel cat | charlesakeem | Multihulls | 10 | 10-01-2008 10:54 PM |
| 6 foot by 8 foot homemade barrel raft | StabbyJoe89 | Boatbuilding | 1 | 08-01-2008 09:47 PM |
| How long will interior paint on steel last? | hiracer | Metal Boat Building | 21 | 07-12-2006 12:51 PM |
| 40 foot steel board | JamesH | Boat Design | 0 | 10-05-2005 02:33 PM |
