Old 10-07-2009, 02:27 AM
Samnz Samnz is offline
Rep: 42 Posts: 196
Originally Posted by themanshed View Post
In question of AMA / hull volume percentage how is the volume calculated?
I'm also looking for suggestions on Carbon Tube contruction.
calculate weight of boat sailing including crew vs the volume in kgs of the float.
i.e 500kg boat with 1000kg floats equals 200% boyancy in floats.
less than 150% floats will make it almost impossible to fly the main hull, less then 200% and you still will barely see the floats when flying the main hull, 300%+ is required if your planning on sailing around with the main hull out (i.e seacart 30)
Old 10-07-2009, 06:06 PM
themanshed's Avatar
themanshed themanshed is offline
Rep: 162 Posts: 135
Thanks Samnz,
Very rough calculations put me at 300% - 350% if I leave the grog on shore. Looks like I'm flying.
Boat and crew less then 1000lbs that allows for 500lbs of designed weight (before carbon and foam design change), and 500lbs of crew.
AMA's had 1400 lbs displacement each before 3 inches of additional freeboard and 1 inch of additional beam was added in with design change.
I was told by Kurt that it will easily fly the main hull.
Carbon tubes anyone? I've read several article on Shrink-Wraps, "Chinese Finger Tubes", and the stand-by of vacuum bagging.
Old 10-12-2009, 09:48 PM
themanshed's Avatar
Rep: 162 Posts: 135
Ok starting to feel a bit better shoulder is working now so I'm back at it....slowly. The Farrier guys will have a go with this post. Starting to bog out the outside of the hull. The foam and glue sand at different rates so I gave it a basic shape with an in-line air sander. Now a coat of bog and it will all sand evenly.
New Design TMS-20 Racing Trimaran-p1010129.jpg  New Design TMS-20 Racing Trimaran-p1010134.jpg  New Design TMS-20 Racing Trimaran-p1010145.jpg
Old 10-12-2009, 10:04 PM
redreuben redreuben is offline
redreuben
Rep: 164 Posts: 352
I would have to disagree with your sequence here, I would be glassing the foam first before screeding with bog. If you have a few rough areas/edges after shaping the foam bog and then glass over wet on wet.
I think this sequence has the potential to get very ugly not to mention heavy.
When using foam like this the filler/ adhesive used when joining the foam only needs to be as strong/dense as the foam itself, same with woodstrip too actually. Good luck!!
Old 10-12-2009, 11:04 PM
themanshed's Avatar
Rep: 162 Posts: 135
Well taken but it is easier to sand bog and foam then carbon fiber. The key is to have it very fare before vacuum bagging on the carbon skins. Once the skins are on you do not want to sand them. It will only have two layers of 200gram carbon not much to fare out without cutting into the skin. I spoke to my NA about this process this is the proper way. Most of the bog will be sanded down in the faring process. You want a smooth void free surface when vacuuming skins.
In the ideal world you are correct I wish my mold was that fare. The attached pic is the inner hull before carbon as you can see there is not much bog after the faring process.
New Design TMS-20 Racing Trimaran-p1010023.jpg  New Design TMS-20 Racing Trimaran-carbon-8.jpg
Old 10-13-2009, 12:22 AM
redreuben
Rep: 164 Posts: 352
Fair enough! I would never advocate sanding into carbon it costs too much to turn it into dust! Can you apply the outside skin without overlapping joins or do you rebate them into the foam?
Old 10-13-2009, 01:31 AM
themanshed's Avatar
Rep: 162 Posts: 135
I will rebate the overlap into the foam. Once I have this side fare and my shoulder heals a tad more I'll start the other side. I need to foam it still. Then when both sides are foamed out and carbon on the inside I need to fit the bulkheads and fore spare then join the hulls. Once the hulls are joined I will laminate the outside. I want to lay-up the deck on both hull half’s as one with one run of carbon. So then I’ll cut my rebate when I can actually fit the cloth. On the deck the carbon is from 2 –4 layers. On the hull sides it is 2 layers except for where the beams mount. There will be one layer of 4oz E-glass over the outside to protect the carbon. Between the carbon and E-glass there can be some slight faring if needed at the rebates and seams.
Carbon is costly but I shopped it on the Internet and found a good supplier and purchased a roll at $18 a yard US delivered. I have my contact listed on my website www.themanshed.net The roll was 160 yards so it was costly but not too bad of a deal. I get the Divinecell foam at 50% discount, and 30% off of the West Systems Epoxy. I also picked up a Carbon Tornado Spar , like new - never rigged for $1,300. So all in all for what I have in the boat including NA design fees not that bad. Well my time it keeps me out of the pub.
Old 10-14-2009, 12:46 AM
themanshed's Avatar
Rep: 162 Posts: 135
Nice article thanks Joe!
http://smalltrimarans.com/blog/
Old 10-22-2009, 04:44 PM
ThomD ThomD is offline
Rep: 98 Posts: 375
I like my tube and stays beam on my KHSD 24. Normally beam wall doubles when you go stayless. Carbon is light, but you will also have higher loads on the main hull. The pick-up of using better materials is not always there
  #25
Old 10-22-2009, 05:45 PM
themanshed's Avatar
Rep: 162 Posts: 135
ThomD did you build your boat?
  #26
Old 04-27-2010, 08:22 AM
pdw pdw is offline
Rep: 10 Posts: 13
Almost 6 month without any news! I hope ThomD is OK and that his boat is now finished. ThomD, any news and photos will be appreciated.
Pat
  #27
Old 04-27-2010, 09:24 AM
aka Terry Haines
Rep: 1814 Posts: 3,009
He's still with us but not yet finished see load change going from straight dagger boards to curved?
Dances with Turkeys
  #28
Old 04-27-2010, 10:18 AM
Othmar's Avatar
Othmar Othmar is offline
Multihulls ...
Rep: 10 Posts: 50
Hi,
I build last autumn a fiber glass mast in three pieces. As base I used a standard PVC water pipe 2,5 m length. I built a device for turning the base pipe and annother one for the glass fiber.
The PVC pipe was covered with one layer of corrugated paper, and thin foil.
Hereon I laminated 3 layers of 300 gr fiber. After it was dried, I pulled out the PVC tube for the next piece.
The three basic peaces I glued together to a 7 m kernel. It was stiff enough to stay straight, only supported twice.
At last step I laminated 6 x 600 gr UD glass stripes in line over the whole length of the 7 m. Each stripe covered the half diameter.
By moving the next layers each 45 degrees I get a full covering.
The result was a cheap and strong 7 m mast for my proa. Weight total 12,5 kg. Use carbon instead UD glass ....
  #29
Old 04-27-2010, 04:58 PM
aka Terry Haines
Othmar: interesting approach:did the corrugated paper serve any function other than increasing the diameter of the PVC tube, and what was the finished diameter of the mast?
Dances with Turkeys
  #30
Old 04-28-2010, 01:17 AM
Othmar's Avatar
Multihulls ...
Rep: 10 Posts: 50
The main function of corrugated paper is to make easier pull out the PVC pipe. Otherwise the friction may to high to do it. The last kernel was wrapped so fine, that a little help by my car was need
The diameter of pipe was 75 mm, and the mast at last 90 mm. It's dependent on what kind of corrugated paper is used.
22ft racing tri design henrikb Multihulls 29 10-14-2010 05:29 PM
racing sail design tshino Sailboats 15 10-08-2009 07:40 PM
Ocean Racing Catamaran Design oldsailor Boat Design 3 06-12-2005 08:09 AM
Strake design for racing boat Lancer Powerboats 3 03-01-2004 06:07 AM
Design help needed! Odd racing requirements! Boat Design 1 08-15-2002 01:05 PM
