Old 04-13-2009, 05:40 PM
aitkenkingfish aitkenkingfish is offline
Rep: 10 Posts: 26
new custom cat whats your opinion
I picked this cat up from the builder. he had taken the pair of 50's off & the console planning on turring it into a flats boat. luckily he found a pathfinder he couldnt pass up. so im planning on rigging with a pair of johnson 65's. Ill rebuild thje console with some divinicell i have laying around. what do you think of her any ideas of speed to expect it's 18' with a 8.5' beam
new custom cat whats your opinion-cat.jpg  new custom cat whats your opinion-cat1.jpg  new custom cat whats your opinion-picture-001.jpg
new custom cat whats your opinion-picture-002.jpg  new custom cat whats your opinion-picture-003.jpg
Old 04-13-2009, 07:24 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Looks ok to me. The 2m500 beam is very nice as well, it's going to be stable to walk on.
With 2 x 65 Johnson's you can expect about 15km/hr top speed. With Yamaha or Evenrudes about three to four times as much
Just joking. Depending on the boat's weight and the prop pitch thumb suck you should be able to do 50 to 60km/hr.
With one 115 you should get about 70 to 80 km/hr.
Regards
Fanie
Water ! Just gimme water !
Old 04-13-2009, 07:37 PM
Rep: 10 Posts: 26
You think ill see a higher top end in a single engine install? Better handling with the twin right
Old 04-13-2009, 07:57 PM
Fanie's Avatar
Fanie
Yes you will. I had 2 x 60's on my previous boat, the one I have now has a single 115 on it. Identical hulls on my part, also 5m500.
It depends on what you want to use it for. If you're going sea fishing or something then the 2 motors is a must. For fresh or protected waters the single is ok, but a trolling motor or a small emergency motor is a good idea then.
Regards
Fanie
Old 04-13-2009, 08:03 PM
Fanie's Avatar
Fanie
This depends on the boat. I won't change back to the 2 x 60's, but I use mine for fresh only.
If you do surf launches then the twin would handle better. They get fitted with low pitch props to provide better grip for quick acceleration and better handling in rough water where you have to go slower to keep it safe.
Regards
Fanie
Old 04-13-2009, 08:27 PM
Rep: 10 Posts: 26
Mostly offshore
Old 04-13-2009, 11:26 PM
Rep: 10 Posts: 26
Do you have any pics of your boat fanie
Opinion requested - new design NewIdiot Boat Design 7 02-12-2008 01:08 PM
Opinion on this wood Kraftwerk Wooden Boat Building and Restoration 10 01-31-2007 12:13 PM
Whats the best material for hulls for home built 30' cat John Thompson Multihulls 7 09-12-2006 04:27 PM
Cruiser opinion Ikhanton Powerboats 0 04-14-2004 02:47 PM
opinion Stephen Gray Boat Design 0 02-24-2004 02:40 PM
