Old 12-17-2009, 10:41 PM
Elmo Elmo is offline
Rep: 170 Posts: 32
New 50 ft tri
http://www.neel-trimarans.com/technique-en.html
Old 12-19-2009, 01:13 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2006 Posts: 1,638
Huge credit for re-thinking the cruising tri concept.......but!!
That is one huge weird ass boat!
High performance sailing (cruising) where you stand out on the wing deck....no seat, no protection.....halyards (and sheets?) inside???.......horrible cockpit where you can't see anything with uncomfortable little benches......and those gray hobbit holes to sleep in?
No thanks....huge possibilities though with a new arrangement including a raised (and covered) central cockpit...a big one!
Old 12-19-2009, 05:21 PM
RHP's Avatar
RHP RHP is offline
Rep: 1073 Posts: 568
Interesting but what is the advantage of that boat over a modern catamaran?
Externally it looks like a generic catamaran with an added centre hull.
Old 12-19-2009, 06:50 PM
basildog basildog is offline
basildog
Rep: 10 Posts: 48
This is just plain wrong - sailing along with 3 hulls in the water - no cockpit - water slamming up the wings - and so it goes on.
As someone just said why not a catamaran
Old 12-19-2009, 07:15 PM
glasssurfer glasssurfer is offline
Rep: 10 Posts: 26
that thing is still pretty damn sweet, ive never seen anything like that. im tall, is there enough headroom for a guy whos 6"3???
sweet boat tho, bet it goes pretty fast.
Old 12-19-2009, 09:52 PM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
I am sure the novelty of steering the bastard will wear off pretty quick, imagine standing there all day......wot me worry?
Old 12-20-2009, 04:26 PM
Rep: 170 Posts: 32
Excellent guys !
Thank you for the input.
I don`t think there was a single comment put here that could be disputed.
I posted this because it was different.
I still don`t understand the HUGE volume of those amas.
Cost aside , I could never see myself owning one.
Old 12-20-2009, 05:18 PM
Rep: 593 Posts: 2,054
Originally Posted by Elmo View Post
I still don't understand the HUGE volume of those amas.
Because the boat has a fairly large weight issue that needs to be supported in a wide variety of potential conditions.
Old 12-20-2009, 05:42 PM
boat fan's Avatar
boat fan boat fan is offline
Rep: 357 Posts: 679
That boat does look heavy Chris ....but......overkill it seems .... the amas look as if they have more volume than the center hull.....?
How big a reproduction are you thinking and do you have crew and money dripping off your butt?( PAR2009)
Old 12-20-2009, 05:50 PM
Rep: 170 Posts: 32
I agree ...is this really necessary ?
I would think with amas of that volume , a cat would be more sensible.
No ?
Old 12-21-2009, 03:40 PM
Sinclair D-R Sinclair D-R is offline
Rep: 32 Posts: 16
Neel 50
Good day to all,
This tri,
Designed by famous NA: Michel Joubert and Bernard Nivelt with Eric Bruneel' racing experience and palmares
http://www.neel-trimarans.com/eric-bruneel-en.html
should be given the benefit of the doubt,
to say the least.
Safe winds.
Sinclair
Old 12-21-2009, 06:16 PM
RHP's Avatar
RHP RHP is offline
I agree thats some pedigree but it depends on the design brief surely.
The boat we see is the result of a commission which I dont quite understand.
Old 12-22-2009, 06:17 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
My take on this one -
I like large ama's, I dislike when they drown.
Just two things -
The cabin could have been shortened and they could have made the aft deck larger, extend deck to the rear of the ama's and center hull..
If the cabin was widened the ama's may be used for berthing if accessable form the cabin, yes, similar to a cat.
I doubt it's going to very fast, but it would be a nice stable cruiser.
A cat sits on two hulls at a time, a tri sit on the center hull and gets supported by it's ama's.
In this case it looks like they wanted both ama's to support simultanuously, the width shoud make it fairly stable.
Regards
Fanie
Water ! Just gimme water !
Old 12-22-2009, 07:23 PM
DaveJ DaveJ is offline
Rep: 66 Posts: 131
I'm with you there, the uneducated guess i can come up with is that with all that beoyancy out on the ama's this boat reefing rating is going to be alot higher. But what gets me is it has no traveller and no boom vang. How are they going to control the sail shape in anything other than closed hauled. Afterall thats the big advantage for a multihull, keeping a proper sail shape off the wind.
Old 12-23-2009, 12:42 AM
ThomD ThomD is offline
Rep: 98 Posts: 368
The website answers a lot of the questions posed.
- The amas are designed for light immersion in normal use, not to be a three hull cat. Photos do show windward hull clearance with the water.
- The boat can largely be handled/sailed ? from inside. i don't see an inside helm though maybe there is an auto pilot.
- They really wanted a different layout, what they refer to as a loft. 650 sq feet on one level
- They have good head room even in the mechanical storage area.
- They expect high sailing performance, with 300 mile days.
help with an old Tri kim s Multihulls 24 08-29-2009 02:35 PM
7m tri beams bushsailor Multihulls 21 03-03-2009 05:29 PM
Recycled Tri? rustysunner Multihulls 18 01-29-2009 07:14 PM
Tri-ing? Yes very! Dodgey_rog Multihulls 34 11-06-2006 12:48 AM
Tri performace MMulti Multihulls 15 09-02-2006 06:11 PM
