Old 04-23-2010, 09:35 PM
F3M4 F3M4 is offline
Rep: 24 Posts: 28
My summer power cat build
First off, let me start by saying this website is the best resource I've come across for this subject, and I commend the excellent member base for that.
Now, on to me, I'm a college student at LSU and am in need of something to do over the summer, so I've decided that building a boat was what I wanted to do(after being denied the privilege of buying a motorcycle). This brought me to the problem of what kind of boat to design, which was greatly limited by my ability to store a trailer for the boat. This brings me to my decision to build a catamaran. I plan to have it completely detach so I can move it in my truck, the hulls should be around 10-12 ft long. What I am unsure of is how wide I can get away with, how much weight I can support, etc. I plan to make a frame out of wood and fiberglass over it. The boat will be powered by a jonboat style engine, and the deck should be a trampoline.
I am not trying to make a perfect vessel here, hell all I need it to do is float and be able to move around--it will likely start out with a trolling motor as its propulsion.
Here's what I've come up with thus far, ignore the motor and board, I was just playing around with a method to attach it.
I am also unsure if the hulls should taper on both ends.
Any help is greatly appreciated, and thanks for taking the time to look.
Old 04-25-2010, 12:24 PM
Rep: 24 Posts: 28
anyone?
Old 04-25-2010, 02:31 PM
Previous Member
Rep: 0 Posts: 0
I suggest that you talk with Richard Woods. http://www.sailingcatamarans.com/
Richard has thousands of miles in catamarans and I'm sure that he'll be happy to help you.
Old 04-25-2010, 02:42 PM
SuenosAzules's Avatar
SuenosAzules SuenosAzules is offline
Rep: 10 Posts: 21
Summer Build..
Well building the boat is probably safer than the motorcycle. I would taper both sides of the hull. What are the vessel's dimensions? Good luck with it. What kind of outboard are you planning on using? Send pictures as you get the project going!
Capt. John Banister, Marine Surveyor
Palm Beach Gardens, Florida
www.SuenosAzules.com
Old 04-25-2010, 03:50 PM
Rep: 24 Posts: 28
I will contact him,
Thanks
Old 04-25-2010, 03:54 PM
Rep: 24 Posts: 28
As of now, I'm thinking the hulls will be around 10-12' long, as far as width, I'm unsure how much I can get away with, I would like to find a happy medium as far as "deck" area and stability.
As far as the outboard, I have no reservations as of now, I figure I'll build it, determine how much I can get away with, and then find a used motor(or repair one).
New power cat - help please! foxfish Multihulls 95 05-07-2009 04:44 AM
looking to build aluminum cat need help? korvello Boatbuilding 23 12-28-2008 12:08 PM
Where to build 90 feet aluminum cat economically? richardproeller Metal Boat Building 8 10-22-2006 11:55 PM
power cat boatfan Boat Design 4 08-21-2005 10:37 AM
To build your boat/cat in Srilanka gamage Services & Employment 0 09-03-2002 10:58 AM
