Old 08-15-2008, 07:26 AM
bill_boggia bill_boggia is offline
Rep: 10 Posts: 4
MULTIPLE SPAR HULLS - interconnected
Hi,
I am new to FREESHIP and am thinking of using it to model the stability of an unusual floating structure to check its stability.
The structure consists of a central vertical cylinder (spar) surrounded by 6 equally spaced smaller spars. These peripheral spars are connected by tubular steelwork to the central spar. The geometry is symmetric.
I intend to model the structure in 3D CAD, import surfaces into Polycad, and use Polycad to export into FREESHIP.
Having explored the software I am wondering if FREESHIP will be able to handle this unusual geometry. I intend to have a go and see what happens - but I would be grateful if there is anyone on the forum who might know if FREESHIP can do this kind of a task. I figure that the structure can be modelled as a series of joined surfaces which effectively create a single skin (single hull ?) - albeit of an unusual configuration.
If I am 'barking up the wrong tree' altogether then I would be grateful if someone would let me know before I invest too much time in trying to make this work in FREESHIP.
Sincerely
Bill Boggia :-)
Old 08-15-2008, 08:13 AM
globaldude globaldude is offline
court jester
Rep: 10 Posts: 110
Not fair Bill , naturally we all now want to know what you're up to ! ??.
How stable do you want it and why ? what does it do ?.
I realise you'd probably rather throw a hagiss at me than disclose your secret weapon but don't blame me for asking you , you should have been more subtle with your request .
Globaldude
Old 08-15-2008, 08:30 AM
Rep: 10 Posts: 4
Hi Globaldude,
It's a fair question - but I didne want to get into specifics too much as it's a bit commercially sensative at the moment. I'm happy to divulge more once I'm oot the 'firing line'.
It's a floating structure that has already been built and all stability assessments have been made - I am just looking for the cheapest way to check the work already done - independantly.
OK I'll tell you: It's a marine hagis harvester
Bill :-)
Old 08-15-2008, 08:41 AM
court jester
Rep: 10 Posts: 110
I knew it !. LOL , ha, thats exelent . Bloody scottys, youre even funny when we can't hear your accent --- yeah yeah, whart akusent.
Globaldude
Old 08-15-2008, 08:46 AM
court jester
Rep: 10 Posts: 110
Anyway, if its built and you haven't protected your design/IP by now you'll be stuffed unless you haven't disclosed it yet , IE kept it under wraps.
But sooner or later you'll need to trial it - incedently thats your cheapest method -- make that, the ultimate stability test .
Globaldude
Old 09-06-2008, 03:58 AM
Rep: 10 Posts: 4
SSD Calculation Problem
Well I've built my multi-spar model in COSMOS, imported the iges into Rhino evaluation version and upgraded the surface definition to Bspline.
Exported into PolyCAD and used the .geo file for import into Freeship.
Model check in Freeship says 'Model OK'
Input project information in the project dialogue box and proceeded to CALCULATION and got the following error message whilst calculating cross curves:
'Calculation SSD is impossible - internal volume do not close, or increase estimated Z of CofG'.
I checked all the surface normals and they show arrows on the outside of the surface pointing into the surface - presumably this represents the direction of the water pressure and is therefore OK ?
I have tried increasing the Z elevation for the CofG but get the same error message.
Incidently - cross curves do get plotted - but because of the error message I do not know if I can trust them.
Can anyone shed some light on this for me please.
Thanks
Bill :-)
Old 09-07-2008, 09:33 AM
Spiv's Avatar
Spiv Spiv is offline
Ancient Mariner
Rep: 195 Posts: 169
Did you ask Victor?
Bill,
do you know of Victor?
He writes Freeship.
You can find his thread here: Free!Ship 2.6+ vs Prediction resistance by Holtrop-Mennen started method .
Not sure if he will answer, but you might ask him the question.
Keep smiling
Stefano
Bilge sumps for multiple pumps ?? Bullshipper Boat Design 3 06-21-2008 11:13 PM
Multiple fuel tank draining query cardboard Open Discussion: All Things Boats & Boating 9 02-20-2008 05:14 PM
Moving multiple control points in FreeShip SeaSpark Software 4 06-15-2006 06:02 AM
Sailing efficiency: % or multiple of windspeed Doug Lord Sailboats 7 04-24-2005 05:14 PM
Using multiple bulbous bows as blocks? 8knots Software 3 04-22-2003 06:27 AM
