| multihull weight I looked at the weights of the seacart 30 1060kg seaon 9.6 3000lbs F31 about 4000lbs and the DF31 kurt hughes design 2250 lbs... why is kurts boat lighter than the carbon fiber boats?
__________________ http://janetcg32.blogspot.com |
| I'm going to go out on a limb here and suggest that the reason one boat weighs less than the other is because there's more stuff in the other boat. Either that, or physics is involved in some way. |
| There are other dimensions other than length of hull. width, height, overall width of the boat. Even curving the deck can take off several hundred pounds. I kinda remember that if it is a Kurt Hughs cylinder build design, there is glass reinforcement only on the outside of the hull. |
| Also, let’s compare apples with apples… Are we talking unladen weight or displacement? Looking at other catamarans in that range, I would suggest that those figures are more likely to be displacement (unladen boat plus designed payload) in which case one is designed to carry less load than another.
__________________ Trev F – Amateur designer and part-time layabout. |
Ian Farrier specs for F9R approx bare weight-2750lbs load capacity-2700lbs. Farrier has a website if you want to check his homebuilt versions and i have just started building a F82R. |
| Sweet! I ordered the plans and materials for the DF31 swing wing design. I'm going with Rohacell, s glass outside skin and I want to do a carbon/kevlar inner skin but I'm not sure I can swing that. good to see ya baron!
| Q about multihull | GWEE | Multihulls | 2 | 11-30-2006 10:07 AM |
| Power multihull | taniwha | Powerboats | 21 | 10-21-2006 06:57 AM |
| wet weight vs dry weight of Diesels... | spank | Boat Design | 3 | 10-20-2006 03:16 AM |
| Average Human Weight, Safe Excess Weight, &c. | Free Pirate | Boat Design | 12 | 03-14-2005 01:40 AM |
| Multihull Resistance | Stephen Ditmore | Software | 2 | 12-15-2002 05:39 AM |
