| Multihull Collision Survivability Hi all, I've searched the forums and can't find anything on this. Watching a tv program the other night about a cruising cat hitting a reef and getting stuck on it and sinking made me think about the robustness of a multihull. I mean I've heard of boats colliding with reefs, whales, semi-submerged shipping containers, floating logs etc. The big blue wobbly thing contains enough solid objects that I think it's worth discussing what happens when the light weight foam filled multi hits something hard with it's superior speed compared to a mono. Is it possible for a multi to survive a serious collision at pace and carry on sailing? No hull puncture? Or is this just the domain of steel hulled monos? I get that some foam cored boats float once a big hole is smashed in them, but is it possible to make a multi that is not a big heavy steel dog of a thing survive hitting a shipping container? Perhaps an underwater hull design that allows the multi to ride up over the object it hits? Perhaps the occurance of the above makes it not worthy of discussion? More likely to get struck by lightning? I sure think it would be nice to know your boat could survive such an event ![]() |
| Kung-fu Catri-maran Please just laugh this post off it is stupid, I've had a litre of energy drink and can't sleep. In kungfu I was taught if the object your hitting is hard hit it with something soft, if the object your hitting is soft hit it with something hard. So palm strikes (soft) to the head (hard) and punches (hard) to the stomach (soft) It makes sense, if you punch someone in the head you can easily break your hand........your probably wondering how this relates to the subject. Well I was thinking, say for a sailing multihull boat of any given boat size you had to pick any boat material to crash into a shipping container at 40KPH If you choose steel hulls, it probably won't sail well. If you choose grp/foam hulls, it will probably smash the bows on impact. Plywood, much the same. I think I would choose inflatable hulls, the reason being as the hard object (container) is hit by the soft object (inflatable hull) the hull deforms to the shape of the hard object, absorbing and storing the energy to bounce back into shape moments later. Inflatable hulls are light so the vessel going at 40KPH has less momentum/inertia? Than the steel equivilent. The lighter it is the quicker it is going to stop ramming itself into the hard object. I think inflatables are underated, I have found them in powerboat applications to be very see worthy, a RIB for example compared to the same size and engine equipped aluminium pontoon boat is quicker, more nimble, can carry more payload etc. If inflatable hulls are good enough for the coastguard to rescue you from the most dire situations in big seas then they are good enough for me. The smartkat is a cool idea but I think there could be far more potential for the concept. I have drawn up a rough sketch of a boat that may make you think and or laugh. I'm not sure whether or not it's a cat or tri, hence the name. The outer hulls are inflatable, the main hull is above the water except for the rudder, centerboard and when required outboard. All the accomodation is in the main hull, the main hull is very low to the water to keep the COG low, as such it has a wave deflecting design. The outer hulls are inflatable and have many independant sealed compartments. In a cruising type size I'd guess some rough dimensions of main hull: 12m long 2.5m beam standing height shower and galley. outer hulls: 16m long 1.8m wide at widest point LOA 16m BOA 10m I think if such an ugly design could get to 40KPH and then hit a container the result may be the hull/hulls deform alot, if they ride up the object you could expect the centerboard and rudder to be shorn off. If only the leeward hull were to hit I think the hull would deform alot, round up on the impact point, depending on heal and wind pressure it could produce a pitchpole. If only the windward hull were to hit it could possibly ride over the object, or again round up and pitchpole. I'd be really interested to hear what people think of this wacky concept. ![]() |
| I think the problem with inflatables might be that a shipping container has some sharp corners. If you hit it hard enough, you might tear the fabric. Good multihulls consider the problem of hull damage by compartmentalizing. A collision bulkhead is designed to allow the bow to be torn open without flooding the rest of the hull. |
| Another problem with inflatables is that their internal volume can hold just air, and cannot be used for anything else. So all the accomodations and cargo holds have to go to the main hull, and that's not very space-efficient. Sailboats intended for coastal and off-shore cruising need all the internal space they can get, so I don't see this idea as applicable for them. However, I see that your drawing shows a kind of small multihull raceboat, which could be ok for this solution, imho. |
| I advocated inflatable bow sections on the racers to better cope with damage such as sodebo sustained. Perhaps spare sections could be taken in case of deflation though attaching a section at sea wouldn't be easy. Still a fix a flat approach seems less race ending than the current sacrificial foam section. |
| From my understanding and experience with multihulls (specifically catamarans): Replying in red inline... Quote:
| I apologize for not mentioning in the first posts that I know about multis using collision bulkheads and compartmentalization. RAY Quote:
DAIQUIRI Quote:
CAVALIER Quote:
CATBUILDER Thank you for all that information, very informative. ![]() Re: lightning, hehe the concept above has it's own rubber "gumboots" to help survive lightning ![]() Thanks for putting it in perspective though it's nice to know the relative occurances of these issues. TO ALL I think the idea of having a boat that you know you can peel across the oceans as fast as you like without danger of collision and sinkage would be really cool. I understand water tight bulk heads and how awesome they are to keep a multi afloat. Just imagine though, your on your cruising cat, your asleep in you bed, everything is on autopilot, almighty crash, thrown against bulkhead, bump your head hard? get out to find you've crashed into a container, it's sliced a nice big gash down a third of one hull and your taking on water. Your not exactly going to sail away from this, alot of your worldly possessions are in that hull getting destroyed. It's not an ideal situation, survivable yes, but no jumping for joy. Now your on kungfu, asleep you awake to the feeling of being in a slingshot, you get up to find you've crashed into a container, you've rounded up on it, you drop sails, listen to air hiss out of the forward few compartments. Wait around long enough to be sure you still float ok, then go back to bed to patch or replace the hull in the morning. Some of you may have noticed my dimensions allow the main hull to fit standard trailer regulations, the setup would be easy to demount and trailer because of the low weights of the outer hulls and the low volume of the outer hulls on the trailer when deflated. Some of you may have noticed the much longer outer hulls compared to the main, this is to achieve a much bigger boat for the money, also the forward couple of meters acts as a impact cushion before anything could hit your nice grp main hull. The ugly bumper boat of the 7seas ![]() |
| I know it's just a scenario, but if someone is sleeping below with the auto pilot steering, they do deserve to die for putting others' lives at risk. Breaking that particular law has very serious safety consequences.
| a good compromise would be rotomoulded plastic hulls, you can retain a proper hull shape and they are almost indestructible.
__________________ brendan . |
| Hi Skint, Have a look at the current edition of 'Multihull World', #108 - May/June 2011, (published by Gordon & Gotch in Australia) and you will find an "infomercial" (page 134) near the back of the magazine in collision survivability of ATL products... Their website is www.multihull.com.au
__________________ Try to be helpful... Remember that there are at least two sides for every story... |
| Integrated foam flotation would do all of the same things. It is perfectly suited for a lightweight multi. Put enough off it in strategic locations around the boat and even with the bottoms ripped off you could float and sail with most of the boat out of the water. Watertight bulkheads add even more safety. I like the inflatable idea, but I do not think inflatables are as easy to repair as you believe. Snagged the wrong way and you will end up with a long and impossible to adequately repair gash. And patches over small holes are not as strong or airtight as the original. Air will seep out and you will have to continually blow it back up. Many materials used to make and repair inflatables degrade in UV too. One other concern I would have would be with the lack of weight. It would be easy to get thrown around because you could never build up much momentum. |
| Check out Harry proa - was/is using foam ends on the hulls and the Te pookie on Schachts proafile site - an inflatable proa of almost equal lengths. Great to deflate and transport - then pump up and sail. That said - inflatable materials wont have a long lifespan. I also saw a tv program that tried to destroy a plywood+glass boat on a container and it wasn't as easy as you think - they had to ram it really hard directly on the corner!! Perhaps the bow shape also plays a role? Plumb or curved..... |
| Over is better than into....For the North American West Coast, remember the tsunami debris will be headed this way. |
| I have posted this story before, so I won't dwell on details. In a plywood Tri we hit a deadhead at speed and punched a hole on the main hull. The floats took up the floatation and we sailed on to our destination. As a result of this experience, when I built my Buccaneer 24 we filled the floats with inflatable plastic acid bags just in case the floats got damaged in a similar accident. Very successful and gave great peace of mind. ![]() |
__________________ Keep smiling Stefano |
| Extreme 40 collision-crew jumps for it... | Doug Lord | Multihulls | 0 | 08-01-2010 07:53 PM |
| new to forum - collision damage | nitro23 | Open Discussion: All Things Boats & Boating | 5 | 04-22-2010 10:32 PM |
| Q about multihull | GWEE | Multihulls | 2 | 11-30-2006 10:07 AM |
| Avoidable collision | dereksireci | Open Discussion: All Things Boats & Boating | 7 | 05-17-2006 12:01 AM |
| boat collision | fcfc | Boat Design | 7 | 02-04-2006 10:31 PM |
