#106
| Couch, television, vcr, fridge, 1000 litres cotton wool, insurance policy. Problem irrelevant. FFS, **** HAPPENS ! RR |
#107
| Re. capsize survival: Quote:
I'm very much in favour of painting the underside of any multihull's bridgedeck in bright orange non-skid, and including plenty of tie-off points and grab lines under there. Just in case.
#108
| Foam type The type of foam used as buoyancy foam is important too. Many small boat (amateur) builders advocate mixed, poured polyurethane foam - mainly I suspect because it is simple and easy to use and easily and completely fills compartments before enclosing them.... ...however, my research and forums elsewhere have indicated that PU foam eventually absorbs much of its volume in water, so using this is questionable, especially for vessels which are 'wet'. [NB: I found the PU foam inside the thwarts of my small 'glass speedboat were mostly water after I ground them out to repair failed ply inside. They weighed significantly less after drying out than whenthey were removed. Didn't actually weight them but at least half the weight after drying out]. The consensus appears to be, from what I've read, the order of preference for buoyancy and waterproofness (my word ) is as follows:1. Extruded PolyStyrene (XPS) 2. Expanded PolyStyrene (EPS) 3. Extruded PolyPropylene (EPP) 4. Expanded PolyUrethane (EPU) 5. Foamed (liquid) polyurethane (PU) One thing to note is that EPP is flexible whereas the styrenes are not. I had already been planning to incorporate XPS inside closed compartments so that even if watertight sections were ruptured the amount of water able to 'leak in' would not significantly affect the vessels floatation. I also remember seeing a 'quick and dirty' calc somewhere as to the lift (buoyancy) of XPS but cannot now find it. Do any of the engineers or experts on here know of such a rudimentary 'back of the envelope' method of calculating the desired volume of foam to keep a known weight/mass of hull above water??? Keep It Simple - I need a calculator to balance my chequebook - and often get that wrong! ![]() |
#109
| Standard density EPS varies from 1.3 to 1.9 lbs/cu ft. Fresh water weighs 63 lbs/cu ft and seawater 64. Work it out. Collapsible plastic acid bottles are cheap. Inflated in place make excellent flotation and don't absorb water. In place of brittle styrofoam they don't crumble on impact and so are less likely to be washed out of a hull after a hull fracture, which also can happen with smaller plastic milk or juice bottles. |
#110
#111
| I went with the Air Sea rescue orange non skid underwing some time ago. It didn't cost anything extra or add weight so why not? Years ago I read how the orange underwing Hedley Nicol insisted on for Clipper 1 saved Tom Corkhill when he screwed up which emphasizes a point. You may not make a mistake but if the other watch does everything helps..... |
#112
| Its true, The non-skid can cover up imperfections the fish might find upsetting.... ![]() |
#113
Why not - if you want to protect your vessel - mono - 2 hulls - 3 hulls - - put more (thicker) laminate in the front - most easily damaged areas. If it's wood - then more laninates of wood or carbon or better yet kevlar. Especially if it's attached over an extension filler piece of sacrificial light foam & then wrapped in carbon & kevlar. Better protection (for your life's support systems - ie - the baot - floating) than a lot of weight in some false belief that a bunch of floatation will be good to hang on to as you float around the ocean trying to keep pace with the tsunami floatsam from Japan?????? Food for thought, Yes/no Ciao, james |
#114
#115
| Perhaps we can move posts 111 onward into a new thread titled "Multihull Capsize" Jeff?
#116
| This seems reasonable. The posts dealing with capsize more than collision survival have now been spit to their own thread at Multihull Capsize Prevention <split> This thread here can then continue to discuss collision survivability.
__________________ Please be polite to all other members. Please respect those who take their time to give advice freely. And please keep threads on topic. Forum Rules Last edited by Boat Design Net Moderator : Yesterday at 01:00 AM. Reason: Updated Thread Title. |
#117
Cheers, |
#118
| Now updated. Thanks.
__________________ Please be polite to all other members. Please respect those who take their time to give advice freely. And please keep threads on topic. Forum Rules |
| Extreme 40 collision-crew jumps for it... | Doug Lord | Multihulls | 0 | 08-01-2010 07:53 PM |
| new to forum - collision damage | nitro23 | Open Discussion: All Things Boats & Boating | 5 | 04-22-2010 10:32 PM |
| Q about multihull | GWEE | Multihulls | 2 | 11-30-2006 10:07 AM |
| Avoidable collision | dereksireci | Open Discussion: All Things Boats & Boating | 7 | 05-17-2006 12:01 AM |
| boat collision | fcfc | Boat Design | 7 | 02-04-2006 10:31 PM |
